Full Version: Music fanart broken
...so xbmc just updated T!, right? music fanart is now broke *sigh* :/
it works when browsing recently added albums, but it doesn't in fullscren mode (when you hit tab on the keyboard) - same for the home menu screen.
the other issue with the recently added script, however, is fixed.
will there be a fix any time soon or is there a way to roll back the skin?
love t! (but can't live without music fanarts... lol)
http://forum.xbmc.org/showthread.php?p=7...post769932
maybe due to this, not sure
Maybe check the skin settings?
thx, checking the settings now.
another bug? skin settings - home screen options - tv shows - recently added. switch on > a pop-up: "alarm clock canceled with 719m45s left" huh?! hehe
stokedfish Wrote:it works when browsing recently added albums, but it doesn't in fullscren mode (when you hit tab on the keyboard) - same for the home menu screen.
if you play anything from recently added on the home screen,
you won't get fanart.
nothing i can do about.
it should work fine when playing anything from the musiclibrary.
stokedfish Wrote:another bug? skin settings - home screen options - tv shows - recently added. switch on > a pop-up: "alarm clock canceled with 719m45s left" huh?! hehe
it's a xbmc issue, it's already been fixed (after dharma).
ronie Wrote:if you play anything from recently added on the home screen,
i know that, but it's not what i mean.
works:
browsing recently added music: fanart shows up.
browsing artists: fanart shows up.
does not work anymore but used to work:
(use cases)
playing album in artist browser and pressing tab: black screen.
playing album in recently added browser n going back to home menu: black.
screenshots:
vs
could you check your settings ?
they're available on the fullscreen music osd:
thanks! fanart was NOT enabled. silly me!
nevermind and sorry for the time-waster Sad
(i did not change anyhting after the update tho.
it automagically turned off music fanarts...)
stokedfish Wrote:(i did not change anyhting after the update tho.
when i add new options to the skins it's sometimes necessary to change some other option from enabled by default to disabled by default.
so after updating you might have to reconfigure some things.
ronie Wrote:when i add new options to the skins it's sometimes necessary to change some other option from enabled by default to disabled by default.
well, yes. i see...
but isn't it a bit weird for a fanart skin to have fanart off by default? :confused2:
i'll have another look and see if i can enable it by default again...
ronie Wrote:i'll have another look and see if i can enable it by default again...
changed 'fanart visible in visualization' back to default again in svn.
hope it doesn't confuse the hell out of everyone ;-)
