2011-04-07, 21:10
Hey, I'm running XBMC on a Ubuntu 10.10 with kernel 2.6.35-28 without Pulseaudio, powered by an 2.6GHz Dual Core Processor (Athlon 64 X2 5000) over an ALC889A Sound chipset and Radeon HD3200 with 256mb shared.
Alright, here's the problem: When I'm playing a photo slideshow with some music on the background, when the music changes, it seems there's a battle between both players to see which one has the user' control. At first, the music is swapped, but slideshow freezes between two frames. If I press Play/Pause on my multimedia keyboard, it keeps changing between "Playing/Paused" quickly (there's a small pop-up that shows this). If I press TAB, it changes back to the Music Player, then I must press Pause and play the music again, then press TAB to go back to the slideshow. That's a workaround.
If I press "i" for music info, the bottom bar comes up (not the little Slideshow box with music info, but the one that shows up on the Music app one, taking over all of the screen' bottom), but it comes up all black and slowly, like lagging. If I press "i" again, it keeps coming back and forth quickly, with a 'bugged' appearance.
I have no problem playing the slideshow alone or the Music player alone, (though there are some visualizations on the music player that eats a lot of CPU resources and makes the music jitter, but that's another issue)
Anyone knows what might be causing this? Am I doing something wrong?
If necessary, I can make a short video and post it on Youtube.
After some tests, seems like the Music Player takes over the control, but the Slideshow doesn't want to let go the display, so it freezes and keep repeating between the last 2 frames. Clicking TAB twice fixes this, but I don't want to pick the keyboard and press TAB twice everytime a music changes.
Disabling Music Player visualizations doesn't fix it.
