2011-04-09, 00:09
So I found a cheap deal on a second revo 3610 and I picked it up to use as a dev box and generally play around with.
here is alsamixer
I have set up a 48KHz passthrough device:
I have compiled from git:
I've tried many settings for audio. I've tried audio output=HDMI with downmix on and off, I've tried using force48 under custom for both "audio output device" and "passthrough audio device" I've tried HDMI (alsa) for those two as well and no matter what I do I cannot get audio.
Here is the output of xbmc.log with full debug logging on:
http://pastebin.com/GucNc83u
xbmctest@XBMCLive:~/.xbmc/temp$ uname -a
Linux XBMCLive 2.6.32-29-generic #58-Ubuntu SMP Fri Feb 11 19:00:09 UTC 2011 i686 GNU/Linux
xbmctest@XBMCLive:~/.xbmc/temp$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 0: ALC662 rev1 Analog [ALC662 rev1 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 1: ALC662 rev1 Digital [ALC662 rev1 Digital]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 3: NVIDIA HDMI [NVIDIA HDMI]
Subdevices: 0/1
here is alsamixer
┌───────────────────────────── AlsaMixer v1.0.22 ──────────────────────────────┐
│ Card: HDA NVidia F1: Help │
│ Chip: Nvidia MCP79/7A HDMI F2: System information │
│ View: F3:[Playback] F4: Capture F5: All F6: Select sound card │
│ Item: Master [dB gain: -3.00] Esc: Exit │
│ │OO│ │OO│ │MM│ │MM│ │OO│ │MM│ │
│ 95 100<>100 94<>94 0<>0 0<>0 │
│ < Master > PCM Front Mic Mic Boos S/PDIF S/PDIF D S/PDIF 1 │
xbmctest@XBMCLive:~/.xbmc/temp$ cat /etc/asound.conf
pcm.force48 {
type rate
slave {
pcm "hw:0,3"
rate 48000
17:54:26 T:8948080 M:1738997760 NOTICE: Starting XBMC, Platform: Linux (Ubuntu 10.04.2 LTS - XBMCLive Dharma, 2.6.32-29-generic i686). Built on Apr 7 2011 (Git:20110407-598dfdc)
