Full Version: Change resolution by pressing a remote button?
I've a problem where you may could help me. My HTPC with XBMC is connected to a HD TV and a projector. But the projector doesn't understand the HD signal and so I've to change the resolution from 1920x1080 (50hz) to 1024x768 (50hz) when switching.
Now I'm using a harmomy one remote and an activity called "cinema" - so I'd be happy, if the remote could send a signal like "change to 1024x768" and after watching "cinema" it should also be able to change back with another signal...
Do you have any idea, how I could do that? Maybe there is already a button to change the resolution? May I could use a script and the remote runs this on the XBMC?
Hope you could help me Smile
Greetings
Limx
Hope my english isn't that bad Big Grin
