Full Version: [RELEASE] veetle.com
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
I played with it a bit when you first posted the info, also with vlc (don't recall if V2 or not - I have 1 & 2). vlc seemed happy working from the higher level m3u and fetching the nested m3u's, but would not play anything for me, either.
FWIW, when dealing with http streaming, I always worry a bit about http headers, in particular useragent, as historically I've seen some sources constrain or block on that basis.(ie what does vlc send in header?)
I previously mentioned a google search; I don't remember which source ('cupertino' rings a bell) but for some reason I believe that the player is supposed to auto-increment the filename on an ongoing basis. Just did that search again; nothing is jumping out at me, sorry.
FYI - My dsl went flaky this afternoon and service truck won't arrive until Monday morning. In addition, some RL issues to deal with (funeral Sat.), so I may not active for a few days.
(2012-09-07, 10:27)bitbotherer Wrote: [ -> ]
(2012-09-07, 05:31)mikeriv Wrote: [ -> ]OK I dont see much love for the Raspberry Pi and Raspbmc. I grabbed and uploaded the file avformat-53-arm.so from a working RC4 install and uploaded it. If someone can point me in the right direction maybe we can come up with a working solution.
http://s000.tinyupload.com/?file_id=0056...5486493650
It's the same as the openelec version I posted earlier - that was also for a R-Pi:
04 30 90 E5 00 20 D3 E5 46 00 52 E3 01 00 00 0A 00 00 A0 E3 1E FF 2F E1 01 20 D3 E5 4C 00 52 E3 FA FF FF 1A 02 20 D3 E5 56 00 52 E3 F7 FF FF 1A 03 20 D3 E5 04 00 52 E3 F4 FF FF 8A 05 20 D3 E5 00 00 52 E3 F1 FF FF 1A 05 00 93 E5 30 0F BF E6 08 00 50 E3 64 00 A0 83 00 00 A0 93 1E FF 2F E1
to
04 30 90 E5 00 20 D3 E5 46 00 52 E3 03 00 00 0A 47 00 52 E3 05 00 00 0A 00 00 A0 E3 1E FF 2F E1 00 F0 20 E3 02 20 D3 E5 56 00 52 E3 F9 FF FF 1A 03 20 D3 E5 04 00 52 E3 F6 FF FF 8A 05 20 D3 E5 00 00 52 E3 F3 FF FF 1A 05 00 93 E5 30 0F BF E6 08 00 50 E3 64 00 A0 83 00 00 A0 93 1E FF 2F E1
Found at 0x2AB28........
Thank you! Got my Pi tasting that much sweeter with a little temp veetle fix action!!!
Yeah thanks a lot I missed this on the pi as well.. Much appriciated!
Has anyone considered contacting t0mm0 to fix this plugin yet?
(2012-09-09, 01:07)myteematt Wrote: [ -> ]Has anyone considered contacting t0mm0 to fix this plugin yet?
Hey good idea! Why didnt we think of this soonerHuh
The reason I ask is that I PM'ed him a week or so ago with no answer. Maybe someone has a direct email to him is all. Usually the developer pops in to check his threads & see whats going on.
Additionally, no love for Apple users, NOT ATV? It seems theres a patch for just about every platform except Apple OSX. Can I provide anything to speed this up, excluding coding and compiling? Much love to all that have helped so far. :-)
There is now a fix for Veetle on the ATV2 read more here:
download this file from here
avformat-52-arm-osx.zip http://www.mediafire.com/?dwzpn36eqhsue7p
copy this file to here on your apple tv 2
/private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/system/players/dvdplayer
Once this is done your Veetle will be fixed just been watching it for the last hour
enjoy
@ adult411.. Thanks for the tip. watching Veetle now..
Thumbs Up..
Is there a fix for xbmcbuntu 11.10 yet, if so where can i find the fix
& what would be the path to copy the file to.
Thank you.
(2012-09-10, 02:01)adult411 Wrote: [ -> ]There is now a fix for Veetle on the ATV2 read more here:
enjoy
Does this mean i can also play normal flv streams as well as Veetle.
tks
Um....yes, thats the file I uploaded about 4 days ago - he copied the file to mediafire and posted the news on the Sinful forums without mentioning here Smile
Check posts 275 and 276.
(2012-09-10, 10:10)bitbotherer Wrote: [ -> ]Um....yes, thats the file I uploaded about 4 days ago - he copied the file to mediafire and posted the news on the Sinful forums without mentioning here Smile
Many thanks bitbrother, just tried a Veetle stream and worked 1st time.
what about the apple 1st generation is there a fix
Thanks for the atv2 patch!
(2012-09-10, 15:46)jenniferdiane Wrote: [ -> ]what about the apple 1st generation is there a fix
Post 243 here has the 10.1 (Dharma) Apple TV 1st gen fix. There are some reports it doesn't work on the 11 release (Eden) (post 296) but try it and see if it works for you.
