Full Version: [RELEASE] veetle.com
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
Go to settings, ADDONS, enabled ADDONS, veetle, uninstall
I have been digging around this huge thread to find the Openelec version of the patched file for a Raspberry PI and I cannot tell which is fixed and which is not. Can someone tell me where the file is please?
Hi all,
The plugin https://github.com/sissbruecker/xbmc dont work now on my atv2.
I have xbmc Eden.
Can someone help me please?
(2013-01-07, 23:13)knipser88 Wrote: [ -> ]Hi all,
I have xbmc Eden.
yep it's not working again. channels aren't shown.
Can you make a new thread for this plugin, tomm0 hasnt been online since march 2012 ,so a new thread will be good to find the new plugin instead of going page by page to find a download link, thank you for the hard work
That's odd, it was working without showing the channel count, then it looked like everything was back to normal, now nothing again.
Ok gang. Had a problem with my ATV2 and XBMC, managed to restore it, but unknowingly updates XBMC from EDEN to FRODO. It appears Veetle is once again not working. It appears they either moved or changed the "avformat-52-arm-osx.so" from it's location in ........system/players/dvdplayer. Can anyone help me out here? I could just could back down to Eden but at this point everything is working perfectly and rather not, just want to get Veetle back and running. Log shows similar error from what I remember.
LOG:.
19:57:59 T:143441920 NOTICE: StorageServer Module loaded RUN
19:57:59 T:143441920 NOTICE: StorageClient-2.5.0 Starting server
19:57:59 T:143441920 NOTICE: StorageServer-2.5.0 Storage Server starting /var/mobile/Library/Preferences/XBMC/userdata/addon_data/script.common.plugin.cache/commoncache.db
19:58:03 T:142114816 NOTICE: -->Python Interpreter Initialized<--
19:58:07 T:154607616 NOTICE: -->Python Interpreter Initialized<--
19:58:07 T:154607616 NOTICE: veetle Category ID: 20
19:58:11 T:154607616 NOTICE: Total veetle.com Channels: 201
19:58:11 T:154607616 NOTICE: Flash Enabled veetle.com Channels: 36
19:58:14 T:169558016 NOTICE: -->Python Interpreter Initialized<--
19:58:15 T:169558016 NOTICE: veetle.com Channel ID: 50fdb5548133d
19:58:16 T:169558016 NOTICE: getting: http://www.veetle.com/index.php/channel/...133d/flash
19:58:16 T:169558016 NOTICE: {u'statsServiceEnabled': False, u'payload': u'http://216.221.144.178:80/flv/50fdb5548133d', u'success': True, u'statsServerURL': u''}
19:58:17 T:109834240 NOTICE: DVDPlayer: Opening: http://216.221.144.178:80/flv/50fdb5548133d
19:58:17 T:109834240 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
19:58:17 T:169230336 NOTICE: Creating InputStream
19:58:18 T:169230336 NOTICE: Creating Demuxer
19:58:21 T:169230336 ERROR: Open - error probing input format, http://216.221.144.178:80/flv/50fdb5548133d
19:58:21 T:169230336 ERROR: OpenDemuxStream - Error creating demuxer
19:58:21 T:169230336 NOTICE: CDVDPlayer::OnExit()
19:58:21 T:169230336 NOTICE: CDVDPlayer::OnExit() deleting input stream
19:58:21 T:109834240 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.veetle/?play=50fdb5548133d]
19:58:22 T:109834240 NOTICE: CDVDPlayer::CloseFile()
19:58:22 T:109834240 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
19:58:22 T:109834240 NOTICE: DVDPlayer: waiting for threads to exit
19:58:22 T:109834240 NOTICE: DVDPlayer: finished waiting
20:00:19 T:145416192 NOTICE: -->Python Interpreter Initialized<--
20:00:20 T:145416192 NOTICE: veetle.com Channel ID: 5101898bb9943
20:00:21 T:145416192 NOTICE: getting: http://www.veetle.com/index.php/channel/...9943/flash
20:00:21 T:145416192 NOTICE: {u'statsServiceEnabled': False, u'payload': u'http://216.221.144.241:80/flv/5101898bb9943', u'success': True, u'statsServerURL': u''}
20:00:22 T:109834240 NOTICE: DVDPlayer: Opening: http://216.221.144.241:80/flv/5101898bb9943
20:00:22 T:109834240 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
20:00:22 T:145416192 NOTICE: Creating InputStream
20:00:23 T:145416192 NOTICE: Creating Demuxer
20:00:27 T:145416192 ERROR: Open - error probing input format, http://216.221.144.241:80/flv/5101898bb9943
20:00:27 T:145416192 ERROR: OpenDemuxStream - Error creating demuxer
20:00:27 T:145416192 NOTICE: CDVDPlayer::OnExit()
20:00:27 T:145416192 NOTICE: CDVDPlayer::OnExit() deleting input stream
20:00:27 T:109834240 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.veetle/?play=5101898bb9943]
20:00:27 T:109834240 WARNING: CreateFile, successfuly opened </var/mobile/Library/Preferences/XBMC/addons/skin.quartz/1080i/DialogOk.xml> instead of </var/mobile/Library/Preferences/XBMC/addons/skin.quartz/1080i/DialogOK.xml>
20:00:27 T:109834240 NOTICE: CDVDPlayer::CloseFile()
20:00:27 T:109834240 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
20:00:27 T:109834240 NOTICE: DVDPlayer: waiting for threads to exit
20:00:27 T:109834240 NOTICE: DVDPlayer: finished waiting
I think we all should request rick deckard to come and fix vettle plugin as soon as possible because after the release of frodo final v12 the addon has stopped working.I hope he is doing fine and somewhere around us listening to our desperate requests.
OK gang found the answer to my question that was right in front of me, I was just missing a step, I should know better. Turns out I had to uninstall the old Veetle Add-On and install the other one from the XBMCHUB FUSION server labeled "Veelte-Proxy" in their video category. Working perfectly now on XBMC Frodo on my mac and atv2. It did not have the categories set up like my previous version, but found a link here that has the default.py which puts back that option. I also included on the second link (I hope it is ok the post these links), which provides instructions for setting up "FUSION" which will then appear in your 'Install from zip" menu. The only other bug I am seeing right now in Frodo release is the 'delayed' loading of menus, which maybe will get fixed soon, takes a couple seconds longer then Eden version, however one nice feature is you now can control volume on the ATV2 within XBMC which comes in handy if you are using a Apple Remote. I am sure there are other bugs and/or features I have yet to discover since it is still a new version.
https://sites.google.com/site/myxbmcaddo...edirects=0 (CATAGORIES, I THINK THIS ALSO IS THE FULL FILE FOR VEETLE-PROXY)
http://www.xbmchub.com/blog/2012/04/24/f...-for-xbmc/ (ADDS FUSION SERVER TO ZIP INSTALL MENU)
(2012-09-12, 05:57)meshohel Wrote: [ -> ]
(2012-09-11, 00:28)bitbotherer Wrote: [ -> ]Here is the link to the Apple Gen 1 - 11.0 Eden fix file if you have a problem with the earlier one.
https://rapidshare.com/files/3074703440/...86-osx.zip
Just tested it on one I've got here. You need to make sure your XBMC is upto date first and then copy the extracted file to:
Applications/XBMC.app/Contents/Resources/XBMC/system/players/dvdplayer/
Do not have XBMC running when you copy it.
Worked for EDEN...ATV1>>>>DO NOT COPY WHILE RUNNING XBMC
Dont suppose anyone has a working link to this?
Last week I did a fresh install of Frodo and re-downloaded the plugin from the GitHub repo. For me everything still works as expected (Win8).
Probably won't do any further development on the plugin as I don't use XBMC at all right now. I only stream Netflix through web and use the Veetle Guide for Veetle stuff. However the code is on GitHub if anybody wants to improve on it. I would also help out if there are questions regarding development.
Cheers,
Rick
This is probably a strange request but I thought I would ask it anyway...with sensitive eyes in the room, is there a way to get rid of the pictures by the streams?
(2013-02-14, 18:06)sosaudio1 Wrote: [ -> ]This is probably a strange request but I thought I would ask it anyway...with sensitive eyes in the room, is there a way to get rid of the pictures by the streams?
Use list view instead of thumbnails view
Has veetle stoped working,comfirm please. using veetle plugin master ver 0.2.2
many thanks
win x64
eden
Is there a new way to play veetle links via the LiveStream AddOn? The old one is not working anymore ...
