I have xbmc installed on a laptop (windows 7 Ultmate 64-bit) with internet access disabled!
(outbound port 80 blocked in win firewall) -
The problem is when shows try update there blocked too -
Any suggestions
Dave
You'll need to add a rule allowing access to the servers used for XBMC updates. You might also want to add exceptions for the servers used for scraping. I don't know offhand what these servers are, but I'm sure someone hereabouts knows the IP addresses, or you could use the MS network monitor.
JR
Anyone any ideas?
It's the scraping that I need to update - Anyone know the default Movie and TV Show IP addresses used through XBMC??
Thanks everyone
can you not just whitelist the xbmc.exe app in the firewall to allow it to make connections on port 80?
huh - I never thought of that -
And after all this time -
Thanks - I will use that.
