Hi guys what is the best matx Gigabyte motherboard and AMD cpu out there at the moment?
I will be using it for windows 7, xbmc and downloading.
Ant replies appreciated
thanks eeskro keep up the good work no matter what other people say
eskro raises the right point, that the "best" is really a subjective term. If all you want is a smooth as can be 1080p experience, then you can trust that 760G board and X2 250 to deliver. But it's hardly the best board or chip in terms of overall features or performance. If you intend to use this box for gaming and encoding then you can make some upgrades.
I would agree these are great parts, but if your system demands are pretty low, don't ignore Atom (ION) and Zacate systems as these can be made in much smaller form factor, much lower power, lower heat, and lower noise levels.
Saixbmc Wrote:thanks eeskro keep up the good work no matter what other people say
i'll do my best
but wicky is right too, if your system demands are pretty low,
