2011-04-11, 09:30
I've been a bit messy and left some folders named pretty badly.. For example...
"The.Matrix revolutions xvid ac3 480p"
However, I have used the scraper, and manually searched for "the matrix" and manually searched for the file, added it, saved the corresponding data...
The scraper failed to find or even guess what these files were and left them blank... I think it was due to the "." in the file name as when it was removed it found the corresponding data... Also when I added "." to the rest of the file name (where the current spaces are) it to found the data, meaning I now know I can't have file names with dots and spaces on the same line...
Now, here is my question...
As I added this information to this folder manually (via the Refresh option) and selected it my self, if I rename the folder at a later date, (to the correct file name structure) will xbmc still recognise the data I have scraped? Or will I need to rename the data to match the new folder name... and if so, what to?
Do I just rename the files in the folder to exactly what the folder was/is renamed to?
Does that make sense?
Basically...
Current folder:
The.Matrix Revolutions Xvid ac3 480p/everything in here named in this manner
Changing to:
The Matrix Revolutions 2003/ but data in here still labeled as the structure above... Only the folder name has changed...
Will xbmc recognise my badly labeled dats or will I have to rename it to the new folder name?
Any ideas, sorry for the poor explanation lol
Basically...
Current folder:
Changing to:
