2011-04-11, 13:10
I have a number of Zotac HD-ID11 boxes running Dharma which were built on top of a minimal Ubuntu server 10.10 64-bit install. All have 1GB RAM except for one which has 2GB. The boxes drive several TVs and one projector at 1920x1080 resolution.
These boxes are used to front-end a tvheadend HTSP server to play satellite and cable TV feeds to TVs in a pub and in general this configuration works fine.
However the boxes occasionally crash while running PAL resolution media with the errors:
I have spent countless hours trying to get to the root cause of this, but nothing I have tried has resolved the issue. I've tried 270 (beta) 256 and several 260 (stable) versions of the NVidia drivers, tried adjusting the swiotlb= kernel boot parameter, set the VideoRam option under the Devices section in X, and the NVreg_RemapLimit in /etc/modprobe.d/nvidia to no avail.
The HD-ID11 does not have a BIOS option to change the amount of shared graphics memory, and I have not been able to find any way to adjust it from within Linux. The system reports 256MB from lspci and 512MB is reported by nvidia-settings, but I've found this is normal due to NVidia TurboCache.
A number of posts I've seen seem to indicate that 256MB is enough to drive the display at 1920x1080 (1080p) resolution.
The boxes typically have 300~600MB memory free, but I've occasionally seen as little as 150MB free. However the one box with 2GB has also been prone to crashing with over 1GB free.
Below is a rundown of the system configuration, I hope there is a simple solution to this issue. If there is any other information that could be of help, please let me know.
Thanks,
Tom
17:40:10 T:139825078195984 M:1861103616 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
17:40:11 T:139825101264656 M:1861103616 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
17:40:16 T:139825078195984 M:1859190784 WARNING: CALSADirectSound::CALSADirectSound - device is not able to pause playback, will flush and prefix with 0 frames
17:40:16 T:139825101264656 M:1859190784 ERROR: (VDPAU) Error: The system does not have enough resources to complete the requested operation at this time.(23) at VDPAU.cpp:1111
17:40:16 T:139825101264656 M:1859190784 NOTICE: Attempting recovery
17:40:16 T:139825101264656 M:1859190784 NOTICE: (VDPAU) FiniVDPAUOutput
17:40:16 T:139825101264656 M:1866842112 NOTICE: vdp_device = 0x00000001 vdp_st = 0x00000000
17:40:16 T:139825101264656 M:1866842112 NOTICE: (VDPAU) screenWidth:544 vidWidth:544
17:40:16 T:139825101264656 M:1866842112 NOTICE: (VDPAU) screenHeight:576 vidHeight:576
17:40:16 T:139825101264656 M:1864970240 NOTICE: (VDPAU) Total Output Surfaces Available: 4 of a max (tmp: 4 const: 4)
17:40:16 T:139825101264656 M:1864970240 NOTICE: (VDPAU) Creating the video mixer
17:40:16 T:139825101264656 M:1864970240 ERROR: (VDPAU) Error: The system does not have enough resources to complete the requested operation at this time.(23) at VDPAU.cpp:1111
17:40:16 T:139825101264656 M:1864970240 NOTICE: Attempting recovery
17:40:16 T:139825101264656 M:1864970240 NOTICE: (VDPAU) FiniVDPAUOutput
17:40:16 T:139825101264656 M:1866510336 NOTICE: vdp_device = 0x00000001 vdp_st = 0x00000000
Thanks,
Tom
monitor@monitor06:~$ export DISPLAY=:0 && sudo nvidia-settings -q VideoRam
[sudo] password for monitor:
[color=red]Attribute 'VideoRam' (monitor06:0.0): 524288.[/color]
'VideoRam' is an integer attribute.
'VideoRam' is a read-only attribute.
'VideoRam' can use the following target types: X Screen, GPU.
monitor@monitor06:~$ sudo lspci -v -s 03:00.0
03:00.0 VGA compatible controller: nVidia Corporation GT218 [ION] (rev a2) (prog-if 00 [VGA controller])
Subsystem: PC Partner Limited Device 3100
Physical Slot: 34
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
[color=red]Memory at d0000000 (64-bit, prefetchable) [size=256M][/color]
Memory at ce000000 (64-bit, prefetchable) [size=32M]
I/O ports at ec00 [size=128]
[virtual] Expansion ROM at fcf80000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nvidia
Kernel modules: nvidia, nouveau, nvidiafb
monitor@monitor06:~$ uname -a
Linux monitor06 2.6.35-22-server #33-Ubuntu SMP Sun Sep 19 20:48:58 UTC 2010 x86_64 GNU/Linux
monitor@monitor06:~$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 260.19.44 Sun Feb 27 22:41:03 PST 2011
GCC version: gcc version 4.4.5 (Ubuntu/Linaro 4.4.4-14ubuntu5)
