Full Version: How to configure bluetooth to connect the keyboard? (iscan, pscan, lm accept,master)
Hello!
I can not configure bluetooth. In older versions of bluez was hcid.conf file, through which i can set options iscan, pscan and lm (link mode). In new versions of bluez 4.xx instead of this file is used main.conf and these parameters there is not provided.
How apply these settings to the bluetooth adapter at system startup and when i connect the adapter to the usb port?
In general, the system behaves is not clear. Sometimes the adapter after the system is turned on, and sometimes it turns off.
