2011-04-12, 10:05
I want to use my Thrustmaster Top Gun Fox 2 Pro USB Joystick with XBMC.
I wrote the following file (C:\Program Files (x86)\XBMC\system\keymaps\joystick.0.xml):
I found the joystick name and button id in the XBMC log file:
Remote control via keyboard works fine, nothing happens when I use my joystick, even though it registers the presses.
Debug information also says:
I also found the following in log file:
But using that name doesn't work neither. I enabled and disabled 'Remote control sends keyboard presses' but that doesn't make any difference.
Does anyone have an insight on what's going on here? Help would be appreciated!
PHP Code:
<keymap>
<global>
<joystick name="Joystick 0">
<button id="6">PageUp</button>
<button id="7">PageDown</button>
<button id="2">Select</button>
<button id="5">Pause</button>
</joystick>
</global>
</keymap>
PHP Code:
09:49:05 T:4332 M:2922582016 DEBUG: Joystick 0 button 5 Down
09:49:06 T:4332 M:2922659840 DEBUG: Joystick 0 button 5 Up
09:49:06 T:4332 M:2922659840 DEBUG: Joystick 0 button 6 Down
09:49:06 T:4332 M:2922659840 DEBUG: Joystick 0 button 6 Up
09:49:06 T:4332 M:2922663936 DEBUG: Joystick 0 button 7 Down
09:49:06 T:4332 M:2922668032 DEBUG: Joystick 0 button 7 Up
09:49:08 T:4332 M:2922733568 DEBUG: Joystick 0 button 2 Down
09:49:08 T:4332 M:2922639360 DEBUG: Joystick 0 button 2 Up
Quote:09:58:13 T:6964 M:2858815488 INFO: Loading special://xbmc/system/keymaps/joystick.0.xml
Quote:09:58:13 T:6964 M:2881724416 NOTICE: Enabled Joystick: Top Gun Fox 2 Pro
09:58:13 T:6964 M:2881724416 NOTICE: Details: Total Axis: 4 Total Hats: 1 Total Buttons: 7
