2011-04-12, 14:26
2011-04-13, 18:34
tcman47 Wrote:Loving the Neon skin :
Where would I put movie genre icons and fanart in the skin folder?
TC
The genre icons should be there... The folder structure for genre stuff is:
skin.neon/media/extras/genrefanart
skin.neon/media/extras/moviegenres
skin.neon/media/extras/musicgenres
skin.neon/media/extras/Studios
Thanks,
2011-05-31, 02:44
Let's say you wanted to use your own custom genre icons? Is there a way to get them to show?
2011-06-01, 12:50
I believe if you place them in the folder mentioned they will take precedence over those included by default.
2011-07-18, 17:39
Hi !
first of all, thank you for this skin: it's marvelous !
I put my custom icons in the "skins.neon/media/extras/moviegenres" folder and named them as the genre name they have to replace...
Neon loads the right icons for my "translated-into-italian" genres ("Commedia" in place of "Comedy", for example), but it won't replace it's stock icons for "english-named" ones...
in other words: custom icons won't take precedence over embedded ones...
Is there a solution ?
P.S. It's not a caching problem... Neon acts the same even if you delete the XBMC cached thumbs
2011-07-18, 17:49
Sounds like you'll have to use the version from Git that doesn't get compiled into an xbt file and then replace the images. http://github.com/stoli
2011-07-18, 23:29
Thank you very much...
I'm not using the XBMC Nightly Builds, just the 10.1 stable relase... can I still use a Neon developing package ?
2011-07-19, 16:13
No, the skin has too many changes specific to Eden to use on Dharma. Take the jump to the nightlies!
2011-11-21, 16:56
stoli Wrote:I believe if you place them in the folder mentioned they will take precedence over those included by default.
How do i differentiate between icons and backdrops though?
Soory, It's been a while i know, might not even be relevant anymore.
2011-11-27, 15:57
Just by filenames.
