Hi
I have made two user profiles but I can’t see the log off icon in the “shutdown menu.”
Of course I have enabled it under Skins Settings/Shutdown/ chose the log off icon. But it won’t show up in the menu. :confused2:
Michael
I am running xbmc live 10.1 and Transparency 3.11.5
michael2690 Wrote:I have made two user profiles but I can’t see the log off icon in the “shutdown menu.”
could you check if it's there in Confluence?
michael2690 Wrote:Of course I have enabled it under Skins Settings/Shutdown/ chose the log off icon.
make sure you didn't disable it.
blue=enabled
grey=disabled
ronie Wrote:could you check if it's there in Confluence?
blue=enabled
grey=disabled
Hi Ronie
in the confluence skin I Press the RIGHT key from System menu, and in profiles I was able to activate the logon screen. Afterwards I tryed entering the "shutdown menu" in Transparency, and now it's showing up
. Maybe i'ts missing in the Transparency?
Michael
michael2690 Wrote:Hi Ronie
in the confluence skin I Press the RIGHT key from System menu, and in profiles I was able to activate the logon screen. Afterwards I tryed entering the "shutdown menu" in Transparency, and now it's showing up. Maybe i'ts missing in the Transparency?
Michael
in T! that is:
Settings > Profiles > "press left" > Login screen
ronie Wrote:in T! that is:
Ahhh "the hidden menu", I didn't think of that. thanks mate.
