I've a problem with XBMC on Apple Tv.
The overscan settings via Video Calibration keep resetting now and then.
I searched the forums and see others mention the same thing happening on a variety of platforms. No solution appears to be provided, so am raising this as also occurring on Apple TV 1.
no versions, no xbmc.log... no soup.
Sorry, my bad.
Log excerpt from recent login below:
21:03:33 T:2684407808 M: 36462592 NOTICE: -----------------------------------------------------------------------
21:03:33 T:2684407808 M: 36425728 NOTICE: Starting XBMC, Platform: Mac OS X (8.8.2 i386). Built on Mar 9 2011 (Git:e9e9099)
21:03:33 T:2684407808 M: 36425728 NOTICE: special://xbmc/ is mapped to: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC
21:03:33 T:2684407808 M: 36429824 NOTICE: special://xbmcbin/ is mapped to: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC
21:03:33 T:2684407808 M: 36425728 NOTICE: special://masterprofile/ is mapped to: /Users/frontrow/Library/Application Support/XBMC/userdata
21:03:33 T:2684407808 M: 36429824 NOTICE: special://home/ is mapped to: /Users/frontrow/Library/Application Support/XBMC
21:03:33 T:2684407808 M: 36425728 NOTICE: special://temp/ is mapped to: /Users/frontrow/.xbmc/temp
21:03:33 T:2684407808 M: 36454400 NOTICE: The executable running is: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/MacOS/XBMC
21:03:33 T:2684407808 M: 36450304 NOTICE: Log File is located: /Users/frontrow/Library/Logs/xbmc.log
21:03:33 T:2684407808 M: 36454400 NOTICE: -----------------------------------------------------------------------
21:03:33 T:2684407808 M: 36454400 NOTICE: Setup SDL
21:03:34 T:2684407808 M: 38948864 NOTICE: load settings...
21:03:34 T:2684407808 M: 38940672 ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found
21:03:34 T:2684407808 M: 38936576 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:03:34 T:2684407808 M: 38936576 NOTICE: loading special://masterprofile/guisettings.xml
21:03:34 T:2684407808 M: 38666240 NOTICE: Getting hardware information now...
21:03:34 T:2684407808 M: 38666240 NOTICE: Checking resolution 12
21:03:34 T:2684407808 M: 38612992 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:03:34 T:2684407808 M: 38580224 NOTICE: Loaded playercorefactory configuration
21:03:34 T:2684407808 M: 38596608 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:03:34 T:2684407808 M: 38596608 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:03:34 T:2684407808 M: 38592512 NOTICE: Loaded advancedsettings.xml from special://profile/advancedsettings.xml
21:03:34 T:2684407808 M: 38592512 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<skiploopfilter>48</skiploopfilter>
<osx_gl_fullscreen>true</osx_gl_fullscreen>
</advancedsettings>
21:03:34 T:2684407808 M: 38592512 NOTICE: Getting hardware information now...
21:03:34 T:2684407808 M: 38592512 NOTICE: Checking resolution 12
21:03:34 T:2684407808 M: 38592512 NOTICE: Default DVD Player: dvdplayer
21:03:34 T:2684407808 M: 38592512 NOTICE: Default Video Player: dvdplayer
21:03:34 T:2684407808 M: 38592512 NOTICE: Default Audio Player: paplayer
21:03:34 T:2684407808 M: 38592512 NOTICE: Loading media sources from special://masterprofile/sources.xml
21:03:35 T:2684407808 M: 29831168 NOTICE: GL_VENDOR = NVIDIA Corporation
21:03:35 T:2684407808 M: 29831168 NOTICE: GL_RENDERER = NVIDIA GeForce Go 7300 OpenGL Engine
21:03:35 T:2684407808 M: 29827072 NOTICE: GL_VERSION = 1.5 NVIDIA-1.4.60
21:03:35 T:2684407808 M: 29831168 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.10
21:03:35 T:2684407808 M: 29827072 NOTICE: GL_EXTENSIONS = GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader GL_EXT_multi_draw_arrays GL_EXT_clip_volume_hint GL_EXT_rescale_normal GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_APPLE_client_storage GL_APPLE_specular_vector GL_APPLE_transform_hint GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object GL_APPLE_vertex_program_evaluators GL_APPLE_element_array GL_APPLE_flush_render GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip GL_SGIS_generate_mipmap GL_ARB_shading_language_100 GL_ARB_imaging GL_ARB_point_parameters GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat GL_ARB_shadow GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_draw_buffers GL_ARB_shader_texture_lod GL_EXT_compiled_vertex_array GL_EXT_framebuffer_object GL_EXT_texture_rectangle GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float GL_APPLE_pixel_buffer GL_NV_point_sprite GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_blend_square GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_fog_distance GL_NV_depth_clamp GL_NV_multisample_filter_hint GL_NV_fragment_program_option GL_NV_vertex_program2_option GL_ATI_texture_mirror_once GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
21:03:35 T:2684407808 M: 26697728 NOTICE: start dvd mediatype detection
21:03:35 T:2684407808 M: 26664960 NOTICE: initializing playlistplayer
21:03:35 T:2684407808 M: 26664960 NOTICE: DONE initializing playlistplayer
21:03:36 T:2684407808 M: 20733952 NOTICE: initialize done
21:03:36 T:2684407808 M: 20721664 NOTICE: Running the application...
21:03:37 T:2684407808 M: 19730432 NOTICE: ES: Starting event server
21:03:37 T:52168192 M: 19738624 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
21:03:37 T:52168192 M: 19734528 NOTICE: UDP: Listening on port 9777
21:03:37 T:2684407808 M: 19730432 NOTICE: starting zeroconf publishing
21:03:37 T:52136448 M: 19693568 NOTICE: -->Python Interpreter Initialized<--
21:03:38 T:52283392 M: 7540736 NOTICE: -->Python Interpreter Initialized<--
21:03:38 T:51849728 M: 5894144 NOTICE: -->Python Interpreter Initialized<--
21:03:38 T:51849728 M: 5591040 NOTICE: update library add-on complete
21:03:39 T:52529152 M: 2924544 NOTICE: VideoInfoScanner: Starting scan ..
21:03:40 T:52283392 M: 3403776 NOTICE: {'limit': '4'}
21:04:02 T:52529152 M: 3432448 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:22
HI ! First, this is my first post(or reply) in the forum, I'm an old XBMC user actually, but I always found answers to my problems in the forum
So I also want to take the opportunity to thanks Davilla, and all the team, for their amazing work on XBMC
Thank you all guys !
Then to go back on the subject, after updating to the last nightly build, I'm encountering the same issue !
What ever I do in the calibration screen, when I hit "Menu" to go back, none of my settings are taken in account, and calibration is restored to default.
here is my log :
http://pastebin.com/d2ZvQdJ5
but I think that then, the interesting part is,
my XBMC version :
Quote:18:46:23 T:2684407808 M: 31481856 NOTICE: -----------------------------------------------------------------------
18:46:23 T:2684407808 M: 31465472 NOTICE: Starting XBMC, Platform: Mac OS X (8.8.2 i386). Built on May 12 2011 (Git:20110512-49369a9)
18:46:23 T:2684407808 M: 31465472 NOTICE: special://xbmc/ is mapped to: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC
18:46:23 T:2684407808 M: 31469568 NOTICE: special://xbmcbin/ is mapped to: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC
18:46:23 T:2684407808 M: 31465472 NOTICE: special://masterprofile/ is mapped to: /Users/frontrow/Library/Application Support/XBMC/userdata
18:46:23 T:2684407808 M: 31469568 NOTICE: special://home/ is mapped to: /Users/frontrow/Library/Application Support/XBMC
18:46:23 T:2684407808 M: 31465472 NOTICE: special://temp/ is mapped to: /Users/frontrow/.xbmc/temp
18:46:23 T:2684407808 M: 31469568 NOTICE: special://frameworks/ is mapped to: /Applications/XBMC.app/Contents/Frameworks
18:46:23 T:2684407808 M: 31465472 NOTICE: The executable running is: /Applications/XBMC.app/Contents/MacOS/XBMC
18:46:23 T:2684407808 M: 31469568 NOTICE: Log File is located: /Users/frontrow/Library/Logs/xbmc.log
18:46:23 T:2684407808 M: 31465472 NOTICE: -----------------------------------------------------------------------
and the log content when I open and close the calibration screen :
Quote:18:46:44 T:2684407808 M: 30068736 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
18:46:45 T:2684407808 M: 30158848 DEBUG: ------ Window Init (SettingsScreenCalibration.xml) ------
18:46:45 T:2684407808 M: 30158848 INFO: Loading skin file: SettingsScreenCalibration.xml
18:46:45 T:2684407808 M: 30134272 DEBUG: Load SettingsScreenCalibration.xml: 33.50ms
18:46:45 T:2684407808 M: 30105600 DEBUG: Alloc resources: 35.77ms (33.97 ms skin load)
18:46:46 T:52083712 M: 32849920 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
18:46:47 T:2684407808 M: 32907264 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
18:47:12 T:52034560 M: 33316864 DEBUG: Thread Jobworker 52034560 terminating (autodelete)
18:47:12 T:2684407808 M: 33333248 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-x86-osx.so)
18:47:12 T:2684407808 M: 33333248 DEBUG: Unloading: ImageLib-x86-osx.so
18:47:14 T:52486656 M: 33357824 DEBUG: Thread Jobworker 52486656 terminating (autodelete)
18:47:14 T:2684407808 M: 33415168 INFO: CheckIdle - Closing session to http://mirrors.xbmc.org (easy=0x128a2000, multi=0xeebf590)
18:47:14 T:2684407808 M: 33411072 INFO: CheckIdle - Closing session to http://mirrors.xbmc.org (easy=0x128ab000, multi=0x1246d6b0)
18:47:16 T:52083712 M: 33427456 DEBUG: Thread Jobworker 52083712 terminating (autodelete)
18:47:16 T:2684407808 M: 33468416 DEBUG: CGUIWindowManager:reviousWindow: Deactivate
18:47:16 T:51262464 M: 33411072 DEBUG: Thread Jobworker 51262464 terminating (autodelete)
18:47:17 T:2684407808 M: 33390592 DEBUG: ------ Window Deinit (SettingsScreenCalibration.xml) ------
18:47:17 T:2684407808 M: 33394688 DEBUG: CGUIWindowManager:reviousWindow: Activate new
18:47:17 T:2684407808 M: 33390592 DEBUG: ------ Window Init (SettingsCategory.xml) ------
Thanks beforehand for your support !
PS: I was just thinking, the way to validate the calibration settings didn't change with XBMC on aTV1, right ?
I am having the exact same issue. Had to revert to a previous release to get my apple tv to save the calibration.
for those who are having the issue of video calibration not saving on the latest nightly I messed around and made a way to roll back to which ever nightly I want.
Here is the thread I made with a little guide on how to do it:
http://forum.xbmc.org/showpost.php?p=798584&postcount=3
Also for those having the issue the last nightly for me that doesnt have that issue is this one: xbmc-20110508-6677a2b-master-x86.dmg 08-May-2011 10:42
18.4009
Thank you for the tip, but on my side I think I'll wait for a proper fix in a next nightly build. I mean, yes it's little bit annoying, but anyway once your video is started, it's not really a big deal (for me at least!).
I have the Same problem, everyday I try out the new update but unfortunately this issue was not fixed yet.
In this thread was already posted a solution, but also unffortunally I am not so god damn expert in computers. Is there a solution for dummies?
Lepaka
Ok guys, I got it , I just download and install over again the xbmc 10.1 Dhrama version and all works well with the video calibration.
The xbmc revision, don't touch it until got it proper fixed
I loose the nice views and screens recently created, but I can watch the movies in a proper size.
Have fun guys
Davilla,
I know you are super/hyper busy with other features that are maybe more important, but could you have a look at this calibration issue ? That would be fantastic !
I already provided my full log in a previous post, and waiting for the soup !!
thanks in advance,
Oliver.
hey guys, for future refrence could you please post your debug logs via pastebin or something similar?
Thank you Davilla,
Working perfectly now, and btw, the new layout is great !
