2011-04-16, 19:06
Hi
I'm currently working on getting XBMC to work properly on the Sapphire Edge HD Nettop.
I installed XBMC Freaks latest Live CD. Most of the things including HDMI Audio, Remote and USB Wakeup are working properly.
My only issue is that with VDPAU enabled, i got random Video artifacts when playing different types of mkv files. I found another User who got the Same problems with this Nettop so i think it is a bug.
The Files play without artifacts on my notebook using DXVA or on a Xtreamer. If i skip back 10sec the same scene plays fine without artifacts.
The debug log is free of error messages.
What i have done so far is test OpenELEC, a Ubuntu Minimal Install with latest unstable XBMC release and Windows 7 with stable XBMC. Nothing solved my problem.
Before i make a bug report on the xbmc bugtracker i want to look for other users with this nettop to test if this happens to them...
So, if you are using this Nettop pleas post your type of setup and if you encounter the same problems.
