Full Version: Spelling mistake on MediaStream Redux
Just wanted to mention there is a spelling mistake on one of MediaStream Redux menu's which seems to defy correction and is really niggling me since my original post was way back in November 2010...
http://forum.xbmc.org/showthread.php?p=637086
My apologies for posting it in the wrong section in the first place. At the time I didn't know any better and I thought it was going to get corrected (as per the response I got)
To get to it from the main screen, go to Configure The System, then Add-Ons Settings - at the bottom the screen it says...
' Edit youe add-ons settings, including. '
I know Jezz_X is working on other skins at present and this one hasn't been updated for a while (and why would it, it's almost perfection) but I hope this gets picked up and corrected as it rather spoils the overall look of the best skin out there!
Heh sorry it is fixed in the SVN like that says its just that the version in the addon repo is still so old and I just havn't found time to fix it maybe pull the svn version of the skin instead from here
PHP Code:
https://jezzxbmc.googlecode.com/svn/trunk/skin.mediastream_redux
I do really want to get around to pushing out another version of the skin but time is far from on my side these days
Thanks for the quick reply but 'pull the svn'?
Not sure what this means? Will browse the forum for help but just in case, does anyone want to point me in the right direction?
Thanks muchly
Don't worry about it if you have never done it before a new version should be hitting the repo any time soon
Just noticed my MediaStream_Redux skin doing a little 'update' on my XBMC - Spelling mistake corrected and all working good.
Thanks very much for doing this
All the best for your future work on all things XBMC Jezz_X
