Full Version: [Windows] XBMC subtitle plugin not working after K-lite installed?
After I installed K-lite, I can't not longer select the button to search for subtitle's Sad
If the subtitle file is allready there, XBMC plays the subtitle.
I tryed uninstall XBMC subtitle plugin and reinstall again, didn't help Sad
Is there a way to reset the plugin, or is there a other way to fix it? Confused
No help? Sad
