Full Version: Record button project mayhem skin
hi
can anyone help me.basically on latest versions of media center im unable to record webradio streams as the record button is grayed out,but however im able to only on the top 500 list.ive tried searching but to no avail,if someone could help me i would be very greatful as this is probably something simple like a .xml edit.
many thanks for your time
hi again just wanted to follow up and :bump: this topic if someone could help me i would be extremely grateful as ive tried everything and had no luck and i no it cant be xbmc itself as i can record the top 500 but not in webradio browser.
thanks again!!
i think the record option is only available for some types of streams. but i dont think the top500 uses anything different....
it might have to be fixed on the kml server thing though cause i think the actual interface is streamed from the internet...
course i could be wrong and stupid :-)
files,inxmbc,search scripts activate.py and continue throughb/select tomain music record or no?
do you have streampack?
streampack ! the best pack for stream files...
how many stream links do you think you will find in this pack ??
not less than 9000 !!!! amazing isn't it ?
find the pack in here (download section) :
http://xbmc-stream.gueux.be/index_eng.php
and of course ! if you want to add you streams ! please have a look for our database :
http://xbmc-stream.gueux.be/test/pcstream
a python script to read the database ?? no worries :
http://xstreampack.free.fr
welcome with streams !!!
hello again
sorry fiendish what do you mean how do i activate the record button,only like i say its laways greyed out and i cant select it
