2011-06-06, 17:33
Slurrrp Wrote:Thanks a lot! Maybe you can share the incomplete videoOSD aswell?
So we can use our own buttons in the meantime... sorry i'm so impatient, but i love your mod.
OK, I create this as you want, download this
Slurrrp Wrote:mstef, awesome, very much appreciated!
Maybe you should also include the xbmc subs xml, because the orginal will overlap with your mod...
this is mine, a quick and dirty edit, had to remove the scrollbar because i couldn't get that alligned properly.
http://www.mediafire.com/?gkhc3ih3d4x3vq7
mstef Wrote:I have also this alternative version:
Slurrrp Wrote:Nice. I do like the the buttons (audio, video) but don't like the extra stuff, i think. When pressing 'm' or 'enter' i dont have to see the movie poster or episode image.
But then there's no more place for the buttons... Anyway i would like to try it out.. so pls share
And i'm now using xperience1080's pause, play etc icons, i think they look good with this skin and your mod.
paul Wrote:Hi Mstef would these be of any use to you not tried to add them myself as i have been too busy lately.
Download here http://dl.dropbox.com/u/3921965/XBMC/fus...sd.com.zip
The circular part can easily be removed then it woul be a fairly simple task of creating focused textures.
Ps really like your latest modpack but i still prefer the original white osd
mstef Wrote:Try this link
Slurrrp Wrote:This is not the alternative version?
Slurrrp Wrote:Thanks! i like it better than the original, but with tv shows it's not right?OK, try again redownload. Sorry, but I do this fast on my knee
Videos and Movies are ok... but tv shows look like this on my system:
mstef Wrote:OK, try again redownload. Sorry, but I do this fast on my knee
henrikyo Wrote:I get a recently added error when using this mod, i use eden
