Full Version: Bugg: Readding TV-shows with manual added language in "set content"
This is a bug that has been in XBMC for a long time.
This is my setup now: Ubuntu, XBMC 10.1
Added /videos/series as a share, and set content to tv-show and thetvdb and lang. "en".
Then when I want to add a tv-show that I want swedish as the "info language" for that show, I go to VIDEOS in XBMC (not the library) and go to that specific tv-show in /videos/series/"exampel" and in "set contect" I check that the language shall be "sv" and that this folder contains a single show.
Then when I scan the library, I get swedish lang for this show.
The problem is that when I want to remove this show this show from my library, and I have removed all the files, it comes back when I scan my library again. This time with no episodes of course.
I then have to manually recreate the folder, go back to VIDEOS in XBMC and once again "set content" and go back to normal way without "sv" and single tv-show in that folder.
THEN, I can remove it, and it wont be added back.
Can someone please have a look at this?
/Söder
soder Wrote:This is a bug that has been in XBMC for a long time.
/Söder
Bump? Someone that knows about this problem?
/Söder
The problem is related to this trac ticket is my guess:
http://trac.xbmc.org/ticket/11480
i.e. that path remains in the library so is scanned even though it doesn't actually exist (I presume that you delete the actual disk folder??)
As I indicate in that ticket, it's not necessarily trivial to fix.
jmarshall Wrote:The problem is related to this trac ticket is my guess:
Yes, I've deleted the actual disk folder. But XBMC add the show to the library, even though there is no folder.
/Söder
What if you group all your English shows together say /videos/series(en) and the Swedish ones /videos/series(sv) and set the content different on each?
I know this won't fix the bug - but I use this type of setup for running shows vs cancelled ones and another separate directory for shows that use absolute numbering.
live4ever Wrote:What if you group all your English shows together say /videos/series(en) and the Swedish ones /videos/series(sv) and set the content different on each?
Yeah, I've heard of this way before, but I don't use it. It isn't a THAT big deal for me as it is either, I only wanted it to be reported, as it has been there for a LONG time.
/Söder
Please add your comments to the ticket above.
jmarshall Wrote:Please add your comments to the ticket above.
Done, I think..
/Söder
