2011-05-03, 23:07
Pages: 1 2
2011-05-03, 23:10
Thats what I am just watching at the moment
2011-05-03, 23:22
look in this item list...
http://www.digitalo.de/search/search.htm...ne&sort=5a
maybe theres a case you'll like
2011-05-03, 23:27
Thanks for the link
Actually at the moment I tend to go with the Antec Fusion in black. Costs around 130€ which is really expensive but it looks just great. Very hifi-like!
2011-05-03, 23:30
if its because of the LCD screen, dont go crazy about it,,,
i have it and i know its not that useful...
remote control is also cheap and not responsive...
no good for controling XBMC,,, only good for POWER ON and OFF....
2011-05-07, 08:59
If you do go with a mini ITX build like I did, don't make the mistake of getting that Antec case...it's a POS. There are a number of design flaws. Firstly, the motherboard does not fit properly due to a number of plastic tabs where a second fan would be that stick out too far. Once you have removed those tabs, it still isn't really a great fit. It can fit a low profile video card, but the HDMI port will be covered up. Also some of the cables from the PSU are too short. This case is a disaster, avoid. I ended up getting a SUGO instead, very happy with that choice.
2011-05-07, 14:12
which case exactly Bonzi?
2011-05-07, 20:29
The Antec ISK 310-150 although I know that there may be different models of this case which are perhaps not as bad as the one that I have.
2011-05-07, 22:21
yeah i've heard bad things about the version that has the silent 60W PSU....
2011-05-22, 21:33
Here is another try. This time Mini ITX again because I really like the small form factor at the fact that it is cheaper than the Micro ATX
Case
Antec ISK 310-150: http://www.idealo.de/preisvergleich/Offe...antec.html
Cost: 70€
Motherboard:
ZOTAC GF9300-K-E: http://www.idealo.de/preisvergleich/Offe...otac.html
Cost: 90€
CPU
Intel Pentium Dual-Core E5700 Box http://www.idealo.de/preisvergleich/Offe...intel.html
Cost: 50€
RAM:
G.SKill Ripjaws 4GB Kit DDR3 PC3-10666: http://www.idealo.de/preisvergleich/Offe...skill.html
Cost: 40€
SSD:
OCZ Onyx 32GB SATA II SSD: http://www.idealo.de/preisvergleich/Offe...d-ocz.html
Cost: 60€
I still stick to the Antec ISK 210 - 150 even if Bonzi had same bad expericence. I just read some reviews and they were all quite good. And it is much smaller than the SUGO. In my opinion the SUGO looks like a LAN-Party computer and not like a HTPC
So what do you think of my setup?
Case
Cost: 70€
Motherboard:
Cost: 90€
CPU
Cost: 50€
RAM:
Cost: 40€
SSD:
Cost: 60€
2011-05-22, 21:38
that will be a pretty powerfull little Mini ITX build!
2011-05-22, 21:53
I just ordered it.
Many thanks for your help.
I will keep you updated as soon as i get my delivery
2011-05-22, 21:56
sweet!!
Pages: 1 2
