Full Version: remote temporary unresponsive
Hi!
I use a hid remote controller, which worked fine till 1 month before, but since than, it temporarly refuse to work, and suddenly (after some minutes) it starts working again.
I can't recall, what program or service I set up those days, it's not supposed to affect the working of the usb system.
lsusb:
Bus 003 Device 003: ID 073a:2230 Chaplet Systems, Inc.
dmesg:
Apr 23 19:45:39 ion kernel: [24551.635161] input: HID 073a:2230 as /devices/pci0000:00/0000:00:04.0/usb3/3-2/3-2:1.0/input/input5
Apr 23 19:45:39 ion kernel: [24551.636199] generic-usb 0003:073A:2230.0002: input,hidraw0: USB HID v1.10 Keyboard [HID 073a:2230] on usb-0000:00:04.0-2/input0
If i switch on debugging I see nothing in the xbmc.log (or in `showkey`) on pressing its keys, when it's unresponsive.
Im using XBMC live(10.04, xbmc 10.1) installed to a hard drive.
If I connect the usb->ir to my desktop (10.04 also) it seems to work perfectly.
Do you have any ideas where should I start find the root cause, or just reinstall the system as a solution?
edit: when the hid remote is frozen, I can control the xbmc with my android.
thanks,
mukka
