Jezz_X
Team-XBMC Skinner
<visible>Window.IsActive(videofiles)</visible> doesn't exist anymore but Container.Content(Files) should work for anything with no content set the whole point of it is now the fancy meta data views now work in the files section if it has info
<onclick>XBMC.ActivateWindow(Videos,Files)</onclick> will get you straight to that section
VideoFiles and VideoLibrary now only work for backwards compatibility the correct window name is now Videos for all
spiff
Team-Kodi Member
ActivateWindow(Videos,Live TV - Recorded) should do it.
mcborzu
Skilled Skinner
Also if you need to know what the correct path is for something:
1 add it as a favorite
2 then open up favorites.xml
3 it'll show you what the correct path is
Check out Night - A Skin For XBMC
Hi All & Jezz_X,
I have a modded version of Confluence and it was working perfectly till a couple of nightlies ago, i now with the way ahead and Eden comming out, the nightlies are mirroring more and more toward it. The question i have , is there a break out or all inclusive list of dharma to eden skin syntax changes? i am trying to mod my skin to work with Eden ( and nightlies) , so far it works for the most part but some menu are acting very strange and arent compatible with the new skinning changes. Can any one offer any assistance to help me mod my skin to catch up or point me to a list of , replace this with this, dharma to eden changes?
MrIcka
Senior Member
Is there a away to have the Video button to return to the last position, now the ActivateWindow(Videos,Files) return to the root of the file system every time. Pre Eden it returned to the last location I where in.
Thanks in advance
/Micke
Hitcher
Team-Kodi Member
ActivateWindow(Videos,Files,return)
Again, ActivateWindow(Videos) returns you to where you last were. If you were last in Movies then that's where you go back to.
You cannot force XBMC to go back to somewhere other than where you last were, unless you want it to always go there: ActivateWindow(Videos,where_you_want_to_go).
