Yes it runs on port 9090.
I can't seem to get this to pull pvr channels. They work fine in xbmc, but they do not show on Constellation, just has a blank on the left and on the right says "Preparing data"
Can I get a heads up on what to check?
I'm having the same problem xbmc beta3 with constallation of iPad and iPhone getting the following error JSON RPC failed to connect to port 9090 ?
Any ideas?
i installed xbmc constelation fresh from the appstore and connected via auto-discovery.
listening to music via the file browser works, but when i click for example on albums it says "no albums found". Same when i klick on artists or movies.
i also use the afficial android remote app, and these problems dont exist there.
any ideas how i can get this running in constellation?
thanks
markus
hi,
I m new to the app. I love it except i would like to be able to play a whole season of a tv show as a play list without having to individually add the episodes to the play list.
Is this possible now or in the near future
Thank You
First off...I absolutely love this app on my iPad. Works almost flawlessly and is quite stunning.
I am having one issue with Movie Sets. I scrape all of my movies in XBMC using the TMdB scraper. Problem is that this scraper automatically adds movies to a set as defined by TMdB. For example, Iron Man is placed in an Avengers set. I have noticed in Constellation if a movie has a "set" entry in the NFO and there is not a second movie in that set, the movie does not show in the Movies section (oddly it does show in the recently added row on the home screen.
The obvious solution is to edit the NFO and completely remove the set entry (just making blank does not work). Has anyone found any other workarounds for this?
Are there plans to fix this in the future? I know XBMC only puts movies in a set if there is more than one movie from the set in the library. It would be nice if Constellation worked this way as well.
I still have no epg data, but I do have two more observations.
1. I noticed if I click the "thumbnail" view it does list my stations. Which led to my second observation.
2. I did not do logos as of my last update, so the tiles say the station name, no picture. Maybe this is causing my problem?
I have, since last update cleared the apps cache and database. I closed it out and killed off, and reopened the app to the same results. To recap: that is no station listed on the default view and no epg data, just a thing that says it is loading.
