bobrap
Posting Freak
Great, that worked. Is there a way to send the W key for watched?
YOYIZDERZOMENEMOHOZEZAZEZDENDERIZHOZEZ
2012-04-05, 21:58
(This post was last modified: 2012-04-05, 22:11 by Burbulence.)
I've been playing with custom commends for a while trying to sort out keyboard presses and special buttons... Limited success really, once I have something solid I will report it properly, just a heads up!
As for episode numbers doubling up, it's literally just started doing it on my system, ive just synced the database for the first time since updating constellation v2.1.3
The specific forum for Constellation can be found
Here.
If anyone is looking for a usenet account try
here, great unlimited service!
2012-04-08, 09:24
(This post was last modified: 2012-04-08, 09:25 by DeadpoolSA.)
I've got Constellation running on two different iPads. Both are hooked up to two completely separate instances of XBMC running on different PCs and both seem to be missing several movies that are in XBMC. I've completely reinstalled the app on both iPads. I've even gone so far as to uninstall XBMC and just have a vanilla version of Eden running with no add-ons. Same movies are still missing every time. I used the scraper that's built into XBMC (themoviedb) and the movies all show up fine in XBMC's Movies category. Here's where it gets weird. If I go to the main dashboard on Constellation and pull down the search bar I can find them that way. But they do not show under movies. And no, they are not in collections.
So, any ideas?
i cannot get the video library to show an videos - i can view through Files menu but updating video library does not show any of the mkv, mp4 files visible in the files section
running eden 11.0 on JB ATV2, 2.1.3 on iPad and iPhone 4s ( same problem on both)
thanks
OK, so if those two movies are part of a collection then why doesn't Constellation show a collection if you only have one movie? That seems like a flaw if that's the case. I don't want to edit the NFOs for those files individually. If Constellation can't show a collection with only one film then it needs to have an option to turn collection sorting off.
