2012-09-07, 10:27
(2012-09-07, 00:54)Fibre Wrote: Have htpc windows 7.
Xbmc eden 11
And yes what you are saying is happening
This is a known issue, I believe FSS are looking into it, is your iPad jailbroken?
Xbmc eden 11
(2012-09-06, 09:32)Burbulence Wrote:(2012-09-06, 08:46)Skank Wrote:(2012-09-05, 22:43)Burbulence Wrote: Full sab integration is unlocked by a further in app purchase, without paying you can view items in the queue and add things via couch etc, but can't edit or delete etc...
You could find out if mpc-hc accepts http commands to play pause etc, and if it does set up custom buttons for it on the remote screen of constellation?
This thread here suggests it is possible sending the command number with ip address and port, hope this helps
mmm It looks indeed something like that but im afraid my knowledge doesnt reach that far..
I dont like the idea to change the codes that are sent from constellation, cause then it wont work anymore with normal xbmc
I should somehow find a way to see what commands constellation is sending.. and adjusting this inside mpc-hc...
You would not be changing the constellation, you would be adding custom buttons on to the remote screen Like this
I'll look around later for a sample http command
(2012-09-07, 19:47)Skank Wrote: Found anything?
(2012-09-07, 22:57)Archigos Wrote: Leave it to Apple to piss on the good apps while still doing nothing on all the scam apps that make it through their so-called 'review' process.
(2012-09-06, 21:09)meridius Wrote: There is a Hugh bug in that when u go to the movies and select sort by sort title the app just keeps crashing I can not even access the movies tab anymore as the app keeps crashing.Do you have a lot of foreign (non-english) named titles that have accents? Theoretically Constellation should be able to handle a movie library with an infinite amount of movies, however the more movies you have, the longer it takes... so if your library is really big, you may just need to wait longer for it to finish it's sync before you attempt to do the sort.
(2012-09-07, 10:42)FSS_Dawid Wrote: Well today I will have to start with something really unpleasant...
(2012-09-07, 10:42)FSS_Dawid Wrote: We've been given 24h to do it or the app gets pulled from the AppStore completely. The only parts that will stay are Trakt.TV and sabNZBd...
