darknet Wrote:Hi alexrose1uk
I follow your guide but when play a movie the screen just flicker and nothing play. Is there anything else I need? I really wants to try out this DSplayer. Thanks
Apologies I've not been on much the last day or so, I see you've got it working now. I will edit the guide to make that segment clearer as its something I don't tend to think about, as I know XBMC is x86!
boingman
You have full control over the filters and splitters used.
Want to use Haali? Want to use LAV? Want to use FFDShow? Want to use CoreAVC etc...the list goes on, it gives you that extra segment of control
To be clear, the guide and files I have provided are currently setup so DSPlayer uses the LAV Audio and Video decoder for MKV *only*. Right now, for other file types you additionally need to have FFDShow installed as the guide points out at the bottom, or further amend the mediasfilter.xml file to get other files to ALSO use LAV.
I am looking to change this in the future, but I've been working over most of Christmas/New Years and haven't had a chance.
Edit:
I've now redone the Guide with a new, updated files pack, and some amended and updated instructions.
By default my XML files now remove all references to FFDShow etc, meaning everything should 'work out the box' once you've setup LAV and XBMC correctly, I have also explicitly mentioned you need to install the x86 versions of the LAV filters, even with an x64 OS, to hopefully avoid any users running into this issue.
I haven't had a chance to test every file type available (as I don't have them all), but can confirm MKV, ASF, WMV and MP4 are now all working absolutely fine out the box based on my experience
Also due to further work on the player done by Tiben, I have removed my notes on some of the splitter issues and subtitle issues; as DSPlayer is now working better than ever, and the immediate issues appear to have been resolved. If anyone DOES note any playback bugs, these can now be looked into in the official thread.
i3-2100 /w Scythe Big Shuriken Cooler, 4GB RAM, GT430 Passive, 40GB SSD boot drive, 2TB 5400RPM internal media drive, 2TB external drive, Nexus 430W PSU, Nexus case fans
Feeding Yamaha RX-V1800, Panasonic 42PZ80 Plasma, Mission 753/Quad speaker surround kit
