I'm using an amlogic S905 based hacked android player and it doesn't seem to have the .ISO plugin, so I rip the .ISO to DTS format .WAV files and then send them as passthru HDMI into my LG SN11RG soundbar where the soundbar natively decodes the DTS. Very happy with this setup and the results.
This seems to work beautifully.
I am mostly using this for classical SACD in 5.1 (.iso files)
With .iso having both 2.0. and multi tracks Kodi list it as follows:
01 - blah1 (2.0)
01 - blah1 (multi)
02 - blah2 (2.0)
02 - blah2 (multi)
etc...
Is there anyway to sort it correctly so I can play all multi tracks without skipping through 2.0 tracks ?
I tried different sort settings with no avail.
Thank you for support
jjd-uk
Team-Kodi Member
2021-08-30, 21:27
(This post was last modified: 2021-08-30, 21:27 by jjd-uk.)
Change your track numbering, so if you want the multitracks listed first have them as
101
102
etc
then your 2.0 tracks as
201
202
etc
then you can use Track sort.
jjd-uk
Team-Kodi Member
Doh, my mistake as my mind automatically thinks tagable formats when it comes to music, which is obviously not possible with iso.
