2011-08-30, 00:14
Hi everyone!
I'd like to adapt my keymap to have a better mythbox integration.
Mythbox adds a few windows (id 13000-13007) and i would like to use them in the keymap file to specify special actions when mythbox is active.
The documentation says, that it is possible using the windows ids:
I tried the following entry (also with relative id 3000) but xbmc always falls back to the global section.
Should it work for addons or only for "build-in" windows?
Any ideas?
Thanks,
Christian
Quote:A list of the available window names can be seen here Window IDs. The WINDOW can also be a custom window formatted as <windowId#> (e. g. <window1113>).
<window13000><remote><start>Fullscreen</start><back>XBMC.ActivateWindow(Home)</back></remote></window13000>
Any ideas?
Thanks,
Christian
