Martin75a Wrote:Yes it looks almost the same as your example above.
Here is a guide of how the command line works in SK. (SK calls this Rest.)
Unfortunately I only found it in Swedish. http://www.switchking.se/en/faq/guides/u...-addresses
The code below shows how to switch ON/OFF and dimm a device.
http://servernamn:8800/devices/{id}/turnon
http://servernamn:8800/devices/{id}/turnoff
http://servernamn:8800/devices/{id}/dim/{level}
Martin75a,
I was not able to make a HTTP commandline function yet.
However based on your information above, I have added Switch King as an application to X10-commander light.
If you configure with the pre-definde settings (ON/OFF/DIM/BRIGHT)
it will send the correct URL to switch king
You can also choose for free commands, and then you can define whatever command you want (this is now available to all application X10-Commander, Homeseer, etc...).
So if you want to create something like this
then:
Go to the event you want to configure (XBMC Events/PLAYER Events),
Enable the event you want to configure,
Select the Free definable action
Then you get 2 fields available:
-command, here you fill out:
dim
-value, here you fill out the level you want to give with the command e.g.:
35
In combination with the settings under Host and Devices
a url will be created like:
IMPORTANT:
The Device ID under the device settings, does NOT have to be an X10 address like
A1,
It can also be something like:
Living room, wall
So you can fill out the name used in switch king.
I have made an alpha version of this, which you can download here:
V0.0.6 alpha
There is no manual available yet, it is also not tested fully yet.
