Oh for fucks sake, how old are you, 10? Or course people post feature requests and suggestions when you create an addon this popular. Everyone has their opinion how something should work, that's the way it is.
Yes your addons (this and skin widgets to name couple) are great but the amount of shit that comes out of your mouth is pretty unbelievable sometimes. Take a break from the forum.
2013-09-11, 17:40
(This post was last modified: 2013-09-11, 18:01 by Martijn.)
Ok hereby you take a break for bad language. See you in a week.
They can have their opinion but can't demand anything, period.
It's the way it's asked that matters.
2013-09-11, 22:01
(This post was last modified: 2013-09-11, 22:03 by Martijn.)
You could have jut asked "would it perhaps be possible to use the same files xbmc uses on export". That's one whole other means of asking than "why doesn't it..., it should...."
MilhouseVH asked it a while ago if I could consider it and I said when time permits.
Ok sorry about that I could of worded it better
Keep up the good work.
Artwork Downloader, Is for hollywood only...?
Because my country movies show no provider id.
I create my own logo and enable use local files but it not show.
Can't select local artwork in version 12.0.19 anymore.
Used to be able to select local poster.jpg, clearart.png, logo.png (etc) in version 12.0.18. Now nothing shows up. Custom scan only works sometimes, and yes i have selected USE LOCAL FILES.
Still not working though.
Any suggestions, insight, anything.
Please.
That's already how it should work
Hello, just a question please, when i add new movies artwork downloader will download the box etc but never the disc art, if i create a shortcut for the program and run it manually it gets the disk art no problem.
Is this working as intended and will only get disc art if you run the program addon manually?
Thanks in advance.
2013-09-13, 14:31
(This post was last modified: 2013-09-13, 14:31 by Martijn.)
i said HOW IT SHOULD WORK.
Read my statement again. Could be that due changes it's disabled for now.
I think i know the software better than you.
