I know you requested logs and have a list of requirement for posts to be looked at, but this isn't so much a problem more a question.
I have all my artwork stored locally and configured this in the settings. I have missing artwork and during the course of the last couple of months I've added custom disk art. I add it and then run your program and it picks it up.
If I want to replace some disc art that has already been added, do I just remove the movie from the XBMC library, add and then run your program?
I'm running Fodo 12.2 git 20130502-32b1a5e on Windows 7.
Thanks for a wonderful program and the time you spent making it.
Hope you guys can help and Have a nice Festive season!!!
@ rattyjunk : you have to clean your video database , go into the specific movie info screen, refresh-- locally- then re run AD
or just pick the discart from the list if the skin you use supports it.
if it was already local stored and you replaced it it should auto update after the image cache has expired
Hi.
Just a quick question where I didn't find an answer yet.
Is it possible to move the extra data sub-folders (like extrafanart, extrathumbs, etc.) from the original movie/ media folders? I don't like these sub-folders within my movie/ media folders. I just want to have the movies in there and what's also not nice, it will change my folder creation date.
If so... how (or just to suppress the folder date change)?
THX
Cray242
Is it possible to run it automatically after a library update?
Updates and library clean is autmated by other addons, would be nice if artwork download work that way too.
Why?
Techinal problem or something else?
