Milhouse
Retired Team-Kodi Member
@mato2015: You shouldn't have enabled "Use local files". This addon doesn't support multiple movies in a single folder, and will create a single "poster.jpg" or "fanart.jpg" for all movies in the folder. Reading this thread would have told you that...
Quickest fix is to rescrape your entire library from scratch.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
how to increase the maximum
"maximum ekstrafanart"?
2015-03-31, 17:58
(This post was last modified: 2015-04-01, 06:38 by Flest.)
how to remove a film or series from updates (download)?
or download all the fanart only for one movie or TV series,
and not the whole at once? )))
I downloaded all the fanart, looked at them and removed the bad,
but when adding a new movie, and running plugin again he download fanart that I erased
I've gone ahead and reorganized my "movie" library structure, specifically, organizing each movie into an individual directory of it's own instead of a single directory containing all movie files. The steps I took were:
1) Uninstall Artwork Downloader
2) Remove any folder associated to AD within my Kodi directory
3) Removed sources from Video Library
4) Created individual sub-directories for each movie within my main "Movie" directory, and moved the specific movie file into its respective folder
5) Installed Artwork Downloader, and enabled "Use local files"
6) Re-added sources to Video Library, enabled that files are stored into individual folders, and re-scrapped
7) After files were added to library, I ran Artwork Downloader
The thing is, AD did not download any files after it was executed, displaying that 0 files downloaded. I was expecting to see image files downloaded into the individual movie directories alongside the video file. Did nothing download because I have "Use local files" enabled?
2015-04-05, 11:18
(This post was last modified: 2015-04-05, 11:59 by superfaker.)
Hello guys !
i´ve a problem with Artwork Downloader
The script is able to download all images expect the Logos and Clearart for TV Shows.
IS this a known issue or is it a problem on my side?
config :
Openelec 5.0.8 (Kodi with Neon Skin)
Artwork downloader 13.0.0
TheMovieDatabase Scraper (working with tvdb scraper)
Why is not working with TheMovieDatabase Scraper ?
@Walt74: The link you have supplied for the art contains none of the images you expect to fetch but HD artwork. The latter isn't supported by AD.
Best,
capfuturo
"The world must learn to work together, or finally it will not work at all" - General Eisenhower
2015-04-07, 18:45
(This post was last modified: 2015-04-07, 18:46 by Martijn.)
that would need to be hacked in and just searching for "random" files could become a mess.
not impossible of course
Hitcher
Team-Kodi Member
Once I have added the initial new art type to Kodi (eg ftv) then ListItem.Artwork(ftv) becomes a valid type but Kodi doesn't then add it for new shows or refreshes.
