  • 191
  • 192
  • 193(current)
  • 194
  • 195
  • 208
  Thread Closed
Artwork Downloader
This guy has forked the Add-On and enables manual input of API keys.
Seems to be working fine for me:
https://github.com/mgonzales71/script.ar...ownloader/
(2017-09-07, 00:52)lorcantc Wrote: This guy has forked the Add-On and enables manual input of API keys.
Might have spoken too soon..
where can i found project API key from fanart.tv?
(2017-09-07, 14:29)pacoma2610 Wrote: where can i found project API key from fanart.tv?
- go to fanart.tv
- log in
- scroll down on fanart.tv main page
- clic on "create a key"
- select "create a project key"
Moanbag is in da place!
Hi everybody
I made some test and only changing the API key in fanarttv.py and tmdb.py is enough to make artwork downloader run again........
@Gracus
Thank you very much
So no workaround for android tv users?
Same here, can't find the reason why...
Artwork downloader is working for TV Shows only, not for movies. Anyone else facing the same issue?
(2017-09-11, 18:19)VikkiXavier Wrote: Artwork downloader is working for TV Shows only, not for movies. Anyone else facing the same issue?
yes
Yes !
This is really weird. Download artwork for movies is enabled in settings, and still it wont work
yes
Yes !
Did all of you perform the API keys changes as explain a few pages back?
For me, changing the API Keys for mine, works both perfect, tv shows and movies.
Maybe some issue with your api API keys......
Yes,
For serial is ok, but some movie nothing
For example "Batman and Harley Quinn" he does not find me anything.
  • 191
  • 192
  • 193(current)
  • 194
  • 195
  • 208
  Thread Closed
  • 18 Vote(s) - 4.44 Average
Artwork Downloader4.4418
