Hitcher
Team-Kodi Member
2011-11-14, 23:37
(This post was last modified: 2011-11-14, 23:45 by Hitcher.)
EDIT: When I select a location it doesn't do anything - the field stays blank.
Great my husband is a weather junkie
which nightly is that? latest windows build is two days ago and doesn't have a name provided in the instructions above.
How to use Git
| AMD Athlon II X3 Triple Core Processor 2.9 GHz |GIGABYTE GA-MA785GM-US2H Mobo 2GB DDR2 Ram | MSI N430GT |
| Logitec Harmony Smart Control Remote| 52" Sharp Aquos LED TV | Denon AVR-X1000 |
| Freenas Server with 18TB ASRock Intel Avoton C2750 |
Hitcher
Team-Kodi Member
Thanks Montellese, I was about to post the the Windows nightly failed to appear again.
spiff
Team-Kodi Member
that's just how old add-ons returned it, i cloned how core has always done it. that being said, you can probably have your property, i'll have to check that we have a dedicated localized string for it.
Hitcher
Team-Kodi Member
Appreciated.
I don't know if it's important or not but Current.winddirection in the script isn't formatted the same as the other labels. I know there can be problems on some system with upper and lower case letters so I thought I'd point it out.
spiff
Team-Kodi Member
props are case insensitive so no worries there.
