Jeroen
Team-Kodi Member
Would be nice if we could somehow create a dummy/fake device so that we don't have to skin it "blind".
Hitcher
Team-Kodi Member
Couldn't they have used existing dialogs?
Well, if it's used just for that and there's no easy way to test the skinning than I guess the users can switch to Confluence for setting it up.
Jezz_X
Team-XBMC Skinner
If you try a build from a month ago that xml ronie posted should work because its been changed later to disable the setting if no valid devices are found
`Black
Team-Kodi Member
The xml still works fine for testing the dialogs with the latest build, at least on OS X.
ronie
Team-Kodi Member
make sure you stick the xml i've posted in the dir where xbmc is installed,
not in your userdata folder.
And the right location on OS X is where exactly? Black?
