Just did a Video of my new Ambilight Setting using 78 Channels.
http://www.youtube.com/watch?v=Ij3O3we5Pwc
is there a good 5 sentence how to how to use boblightd on winodws together with xbmc and the boblight addon? I will need it for the new sedu ambilight stripes project here
http://www.computerbase.de/forum/showthr...p=11611601
@ blackbars
weill, its kinda strange that boblight doesn't detect blackbars, i think this sucks a little as it makes the pic much smoother using such deep values like 25% to detect over blackbars... doenst matter at 16 channels ambilight but with 100 it sucks.
I already asked for to change this or ad a formula of weighting. Menas for example a funktion of
-> example
http://www.abload.de/img/gewichtungt0o6k.jpg
f(x) = 0,0004x² - 0,04x + 1
= 0,0004(x - 50)²
-> if param ==1
weighing factor X = 0,0004x² - 0,04x + 1
weighing factor Y = 0,0004Y² - 0,04Y + 1
would mean pixels near to the border will have more and stronger weighing which would mean u can use big blocks of analyse but if there are no black bars, the result should not become that "smooth" as the boder colors are stronger rated.
Maybe anybody is able to add his code to the git of bob too
@ Bob
think abt
@ all
maybe u are interested in my tool to generate a boblight.conf file.
https://dl.dropbox.com/u/21136636/VS/fin...igTool.exe
Works out of box with my upper project stripes.
Another idea was that maybe the boblight addon 4 xbmc can start up boblight with different config files for different aspect ratios.
I can simply generate a boblight,conf for 16:9 movies as well as for 4:3 for example.
This would be cool as well, not that cool lock a real blackbar detection but cool
Edit:
Quote:Xbmc addon, computes led color only on the video rendering. It means that it displays static color in xbmc menu and ignores video ratio -> black bars are ignored.
But It does not detect hard encoded black bars, it will treat them as video and display black color on leds.
Really? What happens if i use boblight-X11 manually to start it on boot. Will this behave the same or not? I am using manual start instead of addon for now due to the menu effect.
i will try.
