2013-04-29, 19:54
(2013-04-27, 15:26)gsjosh Wrote: I'm running Windows 7 with boblightd. I'm actually not sure which version. How do I check this?
Anyway, I used to have a setup that worked flawlessly on XBMC 12.0 but now that I installed 12.1 the boblight add-on isn't working properly?
It installs right, it connects to the daemon fine. There are no errors. XBMC says it has connected to the daemon and in the command prompt I see the daemon reporting "127.0.0.1:5886 connected" and "said hello" messages.
But the lights are not showing anything, not even if I turn on the static lights in the menu. Did anybody else experience this? Anybody else running on Windows 7 who wants to point me to a working daemon?
Hi all, I have been using xbmc now for 2 years or so and had it as my default dash on my xbox for much longer :-) . this is my first post here.
I have exactly the same problem as gsjosh except i never had my leds in place for Xbmc version 12.0
I have windows 7 64bit. I can start boblightd, my 50 leds flash red, green and blue and the command window stays open. I then start Xbmc 12.1 official and "connected to boblightd" shows on the bottom right and no leds flash. (in the command window i can see boblight has connected)
I play a movie and nothing happens with the leds.
For now I am using prismatik with xbmc in "not true fullscreen" mode and it works pretty good but i would still like to see boblight working.
I find that prismatik does not smoothly fade out/in.
Anyway, if anyone could shed some light on this it would be great, many thanks in advance.
Also, im looking for a good config file for 50 leds on a 51 inch tv, running an arduino uno. (ive been searching but to no avail).
