2016-08-13, 12:54
thats the log on kodi side. I guess you need to have a look into the log of boblightd then.
Also as a side note. Whenever the extracted color information is not working, then it is not related to the boblight addon but to the platform specific RenderCapture implementation in Kodi core. The addon only does something like "give me the current image data in 64x64 pixels downscaled). Platformspecific code in Kodi core is responsible to deliver that image data. If it doesn't work for you platform - first try to switch off the Hardware Decoding Feature for the Video. (software decoding should give proper access to the image data on all platforms. Its the hardware decoding that needs to be altered for each platform for being able to extract the image data and whenever hardware decoding code is changed in Kodi - its likely that RenderCapture breaks because most devs are not always aware of that interface which is important for boblight only...).
