Which addon version are you using - latest addon should be able to properly detect the 64 bit runtime (how annoying if it still doesn't)
AppleTV4/iPhone/iPod/iPad: HowTo find debug logs and everything else which the devs like so much:
click here
HowTo setup NFS for Kodi:
NFS (wiki)
HowTo configure avahi (zeroconf):
Avahi_Zeroconf (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
You are running the 32 bit version of kodi - is this by intention? It should be able to load the 32 bit dll fine then ...
click here
NFS (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
I've recently updated my hardware and am now running Kodi 17.3 on a Asus VC65R, Windows 10. My new computer only has USB 3 and USB 3.1 ports. I think this might be causing a problem with boblightd. When I start boblightd, the cmd window opens for a split second, closes, and the lights blink. Also when I run the arduino software, the lights blink real fast as well, where they use to slowly go through the colors. If anyone has any ideas I would be greatly appreciative. Thanks for the support.
sw4y
Senior Member
Hey, thank you guys for your work on this!
I'm using a Lightpack Setup with boblight in Libreelec and it looks amazing!
Is it possible to add a "function" that boblight kills the lights when the htpc goes into suspend while video or live tv is running?
When I turn off the htpc via remote while video is running, the system goes into suspend but the lights stay on like they were in the situation before suspend.
When I stop the video before suspend, everything is fine of course.
sw4y
Senior Member
OK, found out that there is an addon, to toggle boblight on/off.
I have it already working assigned to a key on my remote, that toggles boblight on / off.
Is there a possibility to bind this to the power key on my remote - so that the power key toggles boblight on / off and sends kodi into suspend?
Good morning, I need help with my boblight.
I have configured it all and everything works perfectly, but I only have one problem.
When I have a completely black movie scene the LEDs do not turn off, but they make white light and it's horrible.
Must this be so wrong or wrong with some setting?
I use LibreElec.
Thanks for your help.
Increase the threshold in the boblight addon settings. The higher the setting the earlier boblight will turn off the lights on darker scenes
click here
NFS (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
Not sur of libreelec comes with boblight-constant - this is a command line tool for testing constant colors. Would be interesting if setting color to 000000 (which is black) properly switches off the leds.
click here
NFS (wiki)
READ THE IOS FAQ!:
iOS FAQ (wiki)
