2011-12-21, 08:22
** work in progress **
Ok, i decided to take the plunge here and created this XBMC remote thread...
As you know, there's alot of remotes on the market that can be used to control XBMC..
So my goal here is not to list them all,
and in fact, there's a nice wiki Here for that so,
i strongly suggest you check it out too!
Now, I'm simply trying to do this my way
and list 'easy to use/setup' remote controllers for XBMC.
And by the way,
being a Windows 7 user,
all the solutions described in this thread will of course,
be compatible with windows 7...
Some will work under Linux/Mac but maybe not as 'out of the box' as you'd like so,
i suggest you do some research on your side before buying anything.
that being said, in no particular order, let's begin!!
(see next post plz)
And by the way,
(see next post plz)
