2012-01-15, 17:27
So, I've just brought an Onkyo HTX-22HDX system. Sounds way way better than what was in my TV, as you'd expect.
I've got my HTPC running into the back of it via HDMI and it then passes the video to the TV via its output HDMI. The output on the HTPC is the i3 2100T iGPU HDMI socket. So far, so good. However, if I select either of the digital sound options in the system/audio playback menu, I get a device failed to init error when attempting to playback a file in one of those formats.
In the settings menu I have HDMI selected as the output @ 2.1. Selecting different Audio Devices/Passthrough devices makes no difference at all aside from a few of them removing sound all together.
The receiver shows the input as PCM 44.1hz whatever is input. Put when bringing up the stream information within XBMC on a DTS file, it's showing as outputting as DTS at 1.5Mb/s. Sounds pretty good too.
Here's the debug log of an example file:
http://pastebin.com/6f4Yu1Mz
Any ideas? Thanks.
Any ideas? Thanks.
