  • 15
  • 16
  • 17(current)
  • 18
  • 19
  • 53
[RELEASE] Random and last items smartplaylist script for Skins
Good news !
Thanks Martijn.
Sorry for my english, but, you know, I'm French so ...
Main HTPC : Odroid-C2 running CoreELEC with Titan Bingie
Secondary HTPC : Freebox Mini 4K running Android TV with Titan Bingie
thanks
Version 1.2.4 released
v1.2.4
- [Fix] Albums properties were not cleared properly
- [Add] New property AlbumDesc
Playlist<method>Music<menu>.<# of album>.AlbumDesc = Album N°# description
Will be available soon on official repository.
has anyone ever seen this?
09:11:42 T:1296 WARNING: Unknown sort method 0
09:11:45 T:3048 WARNING: Previous line repeats 27 times.
09:11:45 T:3048 NOTICE: [RandomAndLastItems] ## PLAYLIST special://profile/playlists/video/_ANIME.xsp COULD NOT BE LOADED ##
09:11:45 T:3048 NOTICE: ('[RandomAndLastItems] JSON RESULT ', {u'jsonrpc': u'2.0', u'id': 1, u'result': {u'limits': {u'start': 0, u'total': 0, u'end': 0}}})
09:11:45 T:3048 WARNING: Unknown sort method 0
09:11:45 T:1296 WARNING: Previous line repeats 3 times.
09:11:45 T:1296 NOTICE: Loading PlaylistLastMovie started at 2012-06-26 09:10:07 and take 1.637m
09:11:45 T:3048 WARNING: Previous line repeats 4 times.
Why "_" before ANIME?
that's just how i name things.
what's weird is that it works sometimes... and borks out others
Quote:<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="tvshows">
<name>Anime</name>
<match>one</match>
<rule field="path" operator="startswith">smb://server/_ANIME/</rule>
<order direction="ascending">tvshow</order>
</smartplaylist>
Same NOTICE in LOG :
16:26:55 T:2688  NOTICE: [RandomAndLastItems] ## PLAYLIST  COULD NOT BE LOADED ##
16:26:55 T:1212  NOTICE: [RandomAndLastItems] ## PLAYLIST  COULD NOT BE LOADED ##
16:26:55 T:2420  NOTICE: [RandomAndLastItems] ## PLAYLIST special://profile/playlists/music/U2.xsp COULD NOT BE LOADED ##
16:26:56 T:4060  NOTICE: [RandomAndLastItems] ## PLAYLIST special://profile/playlists/video/cartoons.xsp COULD NOT BE LOADED ##
but everything is OK
I think it's due to JSON security :
http://forum.xbmc.org/showthread.php?tid...pid1017823
I'm mistaken.
I get this NOTICE because I'm on my office PC and my library is empty so cartoons.xsp cannot be loaded because there is no movies to display.
On default skin Confluence, can you browse your smart playlists ?
Video > Library > Playlists > Anime
(2012-06-26, 16:51)mikebzh44 Wrote: I'm mistaken.
i'm actually starting to think it's more of an MySQL problem... my log is flooded with
Quote:09:59:08 T:3924 ERROR: Unable to open database: nguyencongvideo64 [2003](Can't connect to MySQL server on '192.168.1.137' (10055))
09:59:08 T:3924 ERROR: Previous line repeats 1 times.
09:59:08 T:3924 ERROR: Unable to open database: nguyencongvideo63 [2003](Can't connect to MySQL server on '192.168.1.137' (10055))
09:59:08 T:3924 ERROR: Unable to open database: nguyencongvideo62 [2003](Can't connect to MySQL server on '192.168.1.137' (10055))
that continues down to video01 and tries again back @ 64
is there a method of uninstalling this add-on to test... ( can't seem to find it enabled add-ons )
I saw that you've make somes change in $VAR[MusicFanartVar], but it still does not work for meConfused
Just remove or rename the directory.
On Windows XP : C:\Documents and Settings\<user>\Application Data\XBMC\addons\script.randomandlastitems
oups wrong post, sorry
Hi, thanks for this script,
but there's a small problem, i'm getting that parse error script, here's what it looks like :
16:59:54 T:30184   ERROR: JSONRPC: Failed to parse '{"jsonrpc": "2.0", "method": "Files.GetDirectory", "params": {"directory": "C:\Users\DENY\AppData\Roaming\XBMC\userdata\playlists\video\Film_Barat.xsp", "media": "video", "properties": ["year", "runtime", "file", "playcount", "rating", "plot", "fanart", "thumbnail", "trailer", "streamdetails"]}, "id": 1}'
16:59:54 T:30184  NOTICE: [RandomAndLastItems] ## PLAYLIST C:\Users\DENY\AppData\Roaming\XBMC\userdata\playlists\video\Film_Barat.xsp COULD NOT BE LOADED ##
16:59:54 T:30184  NOTICE: ('[RandomAndLastItems] JSON RESULT ', {u'jsonrpc': u'2.0', u'id': None, u'error': {u'message': u'Parse error.', u'code': -32700}})
16:59:54 T:30184  NOTICE: Loading PlaylistLastMovieMenu1 started at 2012-07-03 16:59:54 and take 0.301s
17:00:05 T:28948  NOTICE: Storing total System Uptime
17:00:05 T:28948  NOTICE: Saving settings
17:00:05 T:28948  NOTICE: stop all
I have 2 custom home menus, asian and west movies
Because of this i can't separate recently added asian and west,
That playlist (Film_Barat.xsp) works fine in transparency..
I'd appreciate if you could help me.. Just need this to get my mod done Smile
Could you post Film_Barat.xsp on http://xbmclogs.com/? please.
When you browser this smart playlist, movies are displayed in XBMC ?
  • 15
  • 16
  • 17(current)
  • 18
  • 19
  • 53
[RELEASE] Random and last items smartplaylist script for Skins1
