  • 2(current)
  • 16
[RELEASE] Add-on Metadata Actors - Skin support
#16
Interesting, will definitely look into integrating this Smile
Are you planning to submit this to the official repo too? It would make auto installing this more seamless.
Cheers!
Jeroen Wrote:Are you planning to submit this to the official repo too? It would make auto installing this more seamless.
Later surely, I want a stable version before :p Normally with Eden final
For my bad English, sorry. I am French Canadian.
Admin @ Passion-XBMC.org
@FrostBox
Thanks for the new features !!
Greets
Eisi
@FrostBox
@fmronan
i have now tested your nice addon. But i have some problems. I installed glass from repo. When i select the actor metadata from programms all is fine.
The method to see what movies in my libary with this actor with a hook is good, but my personal favourit is an other color for the field or the font. Second when i scroll through the movies with this actor and found a movie with him in my libary it would nice to play the movie directly with enter or ok button. When i now press enter xbmc pull down and my browser went to tmdb. Thirs is there any chance when i scroll through the movies from the actor that i press i and become the info from this movie ?
Only one little problem and i hope you could tune this a little bit. It tooks many many seconds before shown the actor infos. Any chance to accelerate this ?
Greets
Eisi
You can change that and many things in Glass
@fmronan
i mean only the field with the movies in my libary and not all fonts.
Greets
Eisi
ok, sorry I have many problems with englishRolleyes
Now you can change what color you want for your library
@fmronan
me too, i have the same problems with english Smile
i will gibe it a try
@FrostBox
i have problems with the fanart. When i select a fanart, the fanart is downloading but it will not show me the fanart.
Greets
Eisi
@FrostBox
here is a German translation for your very nice addon.
http://www.loaditup.de/689132-ebm7fzepnq.html
Greets
Eisi
For fanart select just one fanart,
and after if you want extrafanart select more
i have test it with one fanart. He download the fanart but did not show it. Where is the folder he put the fanart ?
Greets
Eisi
userdata>thumbnails/video/fanart
@fmronan
Thanks for the information. But it was all my mistake. I have played with the addon and start the addon from programms direct and not from the yctor in movie info. when i startt the addon under movie info/cast and add then a fanart all is ok.
Greets
Eisi
Skin features
Eisi2005 Wrote:@FrostBox
Added thanks.
And Please if you have a problems with glass and this features.
Post here http://forum.xbmc.org/showthread.php?tid=114839
For a problems with Metadata Actors, submit me a full debug log of XBMC
Add-on update to 0.1.4
- added: [filmography] ability to play trailers (require plugin.video.youtube v2.9.0)
- added: [script-Actors-ContextMenu.xml] on filmography listing
- added: [script-Actors-DialogInfo.xml] Properties: ListItem.Property(extrafanart) and ListItem.Property(extrathumb)
- fixed: [Backend] Window.Property(current.actor.extrathumb)
- added: German language (thanks to Eisi2005)
Cheers
Frost
  • 2(current)
  • 16
[RELEASE] Add-on Metadata Actors - Skin support3
