2012-10-17, 09:17
Hi, I compiled xbmca10 for my melea1000, I have lubuntu v4 with kernel 3.0.42 +, I continue to have problems with the cpu, when I start xbmc cpu working at 95/100%.
(2012-10-17, 05:30)lundman Wrote: If you are playing content over the wired nic, do get the kernel with the fixed nic drivers, otherwise you will get bad playback.
I have binaries for those wanting to test it quickly, although, i think the last upload was a few days ago, so it might not be the very latest.
(2012-10-17, 09:17)ceo16 Wrote: Hi, I compiled xbmca10 for my melea1000, I have lubuntu v4 with kernel 3.0.42 +, I continue to have problems with the cpu, when I start xbmc cpu working at 95/100%.
(2012-10-15, 17:22)Snippo Wrote: I did some testing with the a10 build. Playing video files actually works really well. Great job on that .
And some more observations:
- PVR doesn't work as most add-ons are only compatible with x86.
- It's possible to add TVHeadend channels with the htsp:// protocol. SD channels play fine. HD doesn't work at all.
- Dirty regions doesn't work. Just gives a black screen when it's enabled.
- xbmc freezes quite often, which leads to a restart.
Edit: I should have been reading the readme better...
(2012-10-21, 11:28)Vaevictus2 Wrote: ideally all I want to have do is log in to ubuntu on the mele, run a script and bam have the very latest xbmca10 version from github installed.
