(2012-08-28, 07:51)wxc200 Wrote: The HBR stream could work on Intel's chip now, i will update the patch later.
I didnot find there's attachment option, so i just paste the patch here.
please apply the patch against Takashi's latest sound tree.
i tested this patch on my Yamaha A/V Receiver, both DTS-HD MA and Dolby TrueHD HBR streams
could play well.
Please note this patch is only for test purpose now, it's not the final upstream version.
There's another dependent hack from Anssi, please apply the second patch against Takashi's alsa-lib tree.
If there's any problem during your test, please feel free to let me know:
xingchao.wang@
Intel.com
[PATCH] ALSA: HDMI - Enable HBR feature on Intel chips
HDMI channel remapping apparently effects HBR packets on Intel's chips.
For compressed non-PCM audio, use "straight-through" channel mapping.
For uncompressed multi-channel pcm audio, use normal mapping.
Signed-off-by: Wang Xingchao <xingchao.wang@
Intel.com>
Signed-off-by: Anssi Hannula <
[email protected]>
sound/pci/hda/patch_hdmi.c | 50 +++++++++++++++++++++++++++-----------------
1 file changed, 31 insertions(+), 19 deletions(-)
diff --git a/sound/pci/hda/patch_hdmi.c b/sound/pci/hda/patch_hdmi.c index d9439c5..fda89e3 100644
--- a/sound/pci/hda/patch_hdmi.c
+++ b/sound/pci/hda/patch_hdmi.c
@@ -231,6 +231,11 @@ static struct cea_channel_speaker_allocation channel_allocations[] = {
{ .ca_index = 0x01, .speakers = { 0, 0, 0, 0, 0, LFE, FR, FL } },
/* Dolby Surround */
{ .ca_index = 0x02, .speakers = { 0, 0, 0, 0, FC, 0, FR, FL } },
+{ .ca_index = 0x03, .speakers = { 0, 0, 0, 0, FC, LFE, FR, FL } },
+{ .ca_index = 0x04, .speakers = { 0, 0, 0, RC, 0, 0, FR, FL } },
+{ .ca_index = 0x05, .speakers = { 0, 0, 0, RC, 0, LFE, FR, FL } },
+{ .ca_index = 0x06, .speakers = { 0, 0, 0, RC, FC, 0, FR, FL } },
+{ .ca_index = 0x07, .speakers = { 0, 0, 0, RC, FC, LFE, FR, FL } },
/* surround40 */
{ .ca_index = 0x08, .speakers = { 0, 0, RR, RL, 0, 0, FR, FL } },
/* surround41 */
@@ -239,22 +244,15 @@ static struct cea_channel_speaker_allocation channel_allocations[] = {
{ .ca_index = 0x0a, .speakers = { 0, 0, RR, RL, FC, 0, FR, FL } },
/* surround51 */
{ .ca_index = 0x0b, .speakers = { 0, 0, RR, RL, FC, LFE, FR, FL } },
- /* 6.1 */
-{ .ca_index = 0x0f, .speakers = { 0, RC, RR, RL, FC, LFE, FR, FL } },
- /* surround71 */
-{ .ca_index = 0x13, .speakers = { RRC, RLC, RR, RL, FC, LFE, FR, FL } },
-{ .ca_index = 0x03, .speakers = { 0, 0, 0, 0, FC, LFE, FR, FL } },
-{ .ca_index = 0x04, .speakers = { 0, 0, 0, RC, 0, 0, FR, FL } },
-{ .ca_index = 0x05, .speakers = { 0, 0, 0, RC, 0, LFE, FR, FL } },
-{ .ca_index = 0x06, .speakers = { 0, 0, 0, RC, FC, 0, FR, FL } },
-{ .ca_index = 0x07, .speakers = { 0, 0, 0, RC, FC, LFE, FR, FL } },
{ .ca_index = 0x0c, .speakers = { 0, RC, RR, RL, 0, 0, FR, FL } },
{ .ca_index = 0x0d, .speakers = { 0, RC, RR, RL, 0, LFE, FR, FL } },
{ .ca_index = 0x0e, .speakers = { 0, RC, RR, RL, FC, 0, FR, FL } },
+{ .ca_index = 0x0f, .speakers = { 0, RC, RR, RL, FC, LFE, FR, FL } },
{ .ca_index = 0x10, .speakers = { RRC, RLC, RR, RL, 0, 0, FR, FL } },
{ .ca_index = 0x11, .speakers = { RRC, RLC, RR, RL, 0, LFE, FR, FL } },
{ .ca_index = 0x12, .speakers = { RRC, RLC, RR, RL, FC, 0, FR, FL } },
+ /* surround71 */
+{ .ca_index = 0x13, .speakers = { RRC, RLC, RR, RL, FC, LFE, FR,
+FL } },
{ .ca_index = 0x14, .speakers = { FRC, FLC, 0, 0, 0, 0, FR, FL } },
{ .ca_index = 0x15, .speakers = { FRC, FLC, 0, 0, 0, LFE, FR, FL } },
{ .ca_index = 0x16, .speakers = { FRC, FLC, 0, 0, FC, 0, FR, FL } },
@@ -537,22 +535,36 @@ static void hdmi_debug_channel_mapping(struct hda_codec *codec,
static void hdmi_setup_channel_mapping(struct hda_codec *codec,
hda_nid_t pin_nid,
+ hda_nid_t cvt_nid,
int ca)
int i;
int err;
- if (hdmi_channel_mapping[ca][1] == 0) {
- for (i = 0; i < channel_allocations[ca].channels; i++)
- hdmi_channel_mapping[ca][i] = i | (i << 4);
+ unsigned short val;
+ int tmp_mapping[8];
+ bool non_pcm = false;
+ val = snd_hda_codec_read(codec, cvt_nid, 0, AC_VERB_GET_DIGI_CONVERT_1, 0);
+ non_pcm = !!(val & AC_DIG1_NONAUDIO);
+ if (hdmi_channel_mapping[ca][1] == 0 || non_pcm) {
+ for (i = 0; i < channel_allocations[ca].channels; i++) {
+ if (non_pcm)
+ tmp_mapping[i] = i | (i << 4);
+ else
+ hdmi_channel_mapping[ca][i] = i | (i << 4);
for (; i < 8; i++)
- hdmi_channel_mapping[ca][i] = 0xf | (i << 4);
+ if (non_pcm)
+ tmp_mapping[i] = 0xf | (i << 4);
+ else
+ hdmi_channel_mapping[ca][i] = 0xf | (i << 4);
for (i = 0; i < 8; i++) {
err = snd_hda_codec_write(codec, pin_nid, 0,
AC_VERB_SET_HDMI_CHAN_SLOT,
- hdmi_channel_mapping[ca][i]);
+ non_pcm ? tmp_mapping[i] : hdmi_channel_mapping[ca][i]);
if (err) {
snd_printdd(KERN_NOTICE
"HDMI: channel mapping failed\n"); @@ -686,7 +698,7 @@ static bool hdmi_infoframe_uptodate(struct hda_codec *codec, hda_nid_t pin_nid, }
static void hdmi_setup_audio_infoframe(struct hda_codec *codec, int pin_idx,
- struct snd_pcm_substream *substream)
+ hda_nid_t cvt_nid, struct snd_pcm_substream *substream)
struct hdmi_spec *spec = codec->spec;
struct hdmi_spec_per_pin *per_pin = &spec->pins[pin_idx]; @@ -731,13 +743,13 @@ static void hdmi_setup_audio_infoframe(struct hda_codec *codec, int pin_idx,
* sizeof(*dp_ai) to avoid partial match/update problems when
* the user switches between HDMI/DP monitors.
+ hdmi_setup_channel_mapping(codec, pin_nid, cvt_nid, ca);
if (!hdmi_infoframe_uptodate(codec, pin_nid, ai.bytes,
sizeof(ai))) {
snd_printdd("hdmi_setup_audio_infoframe: "
"pin=%d channels=%d\n",
pin_nid,
channels);
- hdmi_setup_channel_mapping(codec, pin_nid, ca);
hdmi_stop_infoframe_trans(codec, pin_nid);
hdmi_fill_audio_infoframe(codec, pin_nid,
ai.bytes, sizeof(ai));
@@ -1151,7 +1163,7 @@ static int generic_hdmi_playback_pcm_prepare(struct hda_pcm_stream *hinfo,
hdmi_set_channel_count(codec, cvt_nid, substream->runtime->channels);
- hdmi_setup_audio_infoframe(codec, pin_idx, substream);
+ hdmi_setup_audio_infoframe(codec, pin_idx, cvt_nid, substream);
pinctl = snd_hda_codec_read(codec, pin_nid, 0,
AC_VERB_GET_PIN_WIDGET_CONTROL, 0);
1.7.9.5
alsa-lib patch:
From 47b54a7e3b6ba58782348c87c6a83b318d5f8c65 Mon Sep 17 00:00:00 2001
Intel.com>
Date: Tue, 28 Aug 2012 17:11:04 +0800
Subject: [PATCH] HDA-Intel: change CTLINDEX entries for HBR
Fix wrong CTLINDEX for HBR stream.
Intel.com>
src/conf/cards/HDA-Intel.conf | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/src/conf/cards/HDA-Intel.conf b/src/conf/cards/HDA-Intel.conf
index d4f2667..7d6de8f 100644
--- a/src/conf/cards/HDA-Intel.conf
+++ b/src/conf/cards/HDA-Intel.conf
@@ -211,7 +211,7 @@ HDA-Intel.pcm.hdmi.0 {
"cards.HDA-Intel.pcm.hdmi.common:"
"CARD=" $CARD ","
"DEVICE=3,"
- "CTLINDEX=0,"
+ "CTLINDEX=1,"
"AES0=" $AES0 ","
"AES1=" $AES1 ","
"AES2=" $AES2 ","
@@ -234,7 +234,7 @@ HDA-Intel.pcm.hdmi.1 {
"CARD=" $CARD ","
"DEVICE=7,"
- "CTLINDEX=1,"
+ "CTLINDEX=2,"
"AES0=" $AES0 ","
"AES1=" $AES1 ","
"AES2=" $AES2 ","
@@ -257,7 +257,7 @@ HDA-Intel.pcm.hdmi.2 {
"CARD=" $CARD ","
"DEVICE=8,"
- "CTLINDEX=2,"
+ "CTLINDEX=3,"
"AES0=" $AES0 ","
"AES1=" $AES1 ","
"AES2=" $AES2 ","
@@ -280,7 +280,7 @@ HDA-Intel.pcm.hdmi.3 {
"CARD=" $CARD ","
"DEVICE=9,"
- "CTLINDEX=3,"
+ "CTLINDEX=4,"
"AES0=" $AES0 ","
"AES1=" $AES1 ","
"AES2=" $AES2 ","
1.7.9.5
