  • 12
  • 13
  • 14
  • 15(current)
  • 16
Release Re-Touched (touch screen skin for 16x9 and 4x3)
Is this the only Kodi's skin with battery life visualization? Thanks
Do RSS feeds work? I don't see them anywhere after enabling them.
Hello! First of all your re-Touched skin is really good and one of the best by clearness of useful information representaion - great job! Also top panel player is very useful! But, please, make more elegant/beautiful version of home screen and overall design, something like Maximinimalism or Amber etc. Also from top panel player button "Go to the full screen" does not work.
hey,
i currently installed the re-touched skin on my raspberry pi attached to the official 7" raspberry display. It looks cool and works smooth out of the box.
My only Problem is the quit/shutdown button. What can i do to make this button do a shutdown of the raspi instead of quitting kodi and restarting it (openelec installed)
I already checked the home.xml and changed from the onclick action from quit to powerdown() but that change was not successful it still just quits kodi.
So what do i need to change?
kind regards,
(2015-12-04, 13:04)exeding Wrote: hey,
kind regards,
you can try this:
settings > system > power saving > shutdown function > shutdown
and use this in the skin:
<onclick>Shutdown()</onclick>
Do not PM or e-mail Team-Kodi members directly asking for support.
Always read the Forum rules, Kodi online-manual, FAQ, Help and Search the forum before posting.
kind regards,
Hi, do you run the lastest milhouse build of openelec? I do and it works really nice with the display.
Chris
Hey,
currently i run the latest stable openelec but i will try the milhouse one.
The tip with the Shutdown() may work and i will give this a try and report my results.
Since is use this openelec installation as a kitchenradio with weather informations only it would be good to have a short method for poweroff Smile
btw. does somebody know if there exists something like a rainradar map (addon for kodi) to get a feeling if it is safe to travel to work by bike or not?
That would be the last thing missing for my project
kind regards,
I have this skin on RPI2 /kodi 15.2. I have noticed that if I have Conflence as the skin, Pandora loads without an issue, but when I switch to Re-Touched or CarPCTouch (Since I have Raspberry Pi Official touchscreen 7") pandora script fails to load (on the login prompt).
Any pointers?
Is there any way to use a playlist as main menu item? ( e.g. Kids Movies and Movies)
Did anyone figure out a way to add favorited add-ons to main screen? instead of clicking the "favs icon". Thanks!
I love this skin for my tablet! Is there anyway to add plot info to the pause screen?
cant any one pleas write a little DIY on how to change/edit the skins... i really want to learn how do it, but don't know where to start,
it can be like this:
change a button to other names,
How do change image in the model or a button.
where all the files.png and stuff need to be,
there are a few tutorials as well as a very extensive skinning manual on our wiki:
Skin_development (wiki)
(2016-10-02, 22:50)ronie Wrote: there are a few tutorials as well as a very extensive skinning manual on our wiki:
Thanks... this is maybe a stupid qustien, but... is kodi allways kodi... i am starting using rbp carpc.. and whant to edit that... is that the same as eding any kodi skin?
yup.
  • 12
  • 13
  • 14
  • 15(current)
  • 16
  • 5 Vote(s) - 4.6 Average
Re-Touched (touch screen skin for 16x9 and 4x3)4.65
