2012-09-06, 21:43
System/Add-ons/Get Add-ons/XBMC.org Add-ons/Music Video Information/Last.fm for Music Videos
^^ This is the add-on manager...
(2012-09-06, 21:43)olympia Wrote: System/Add-ons/Get Add-ons/XBMC.org Add-ons/Music Video Information/Last.fm for Music Videos
(2012-09-07, 00:33)Gadget Wrote:(2012-09-06, 21:43)olympia Wrote: System/Add-ons/Get Add-ons/XBMC.org Add-ons/Music Video Information/Last.fm for Music Videos
Ok, Thanks, but Last.fm isn't in the list to physically "Add" only "Yahoo Music" is in the list to add, and that has already been enabled, so I guess I'm just going to have to find a different route to get hold of it then.
Thanks again for all the prompt replies
Regards
(2012-09-07, 07:31)Martijn Wrote:(2012-09-07, 00:33)Gadget Wrote:(2012-09-06, 21:43)olympia Wrote: System/Add-ons/Get Add-ons/XBMC.org Add-ons/Music Video Information/Last.fm for Music Videos
Regards
You are using Eden 11.0?
Remove addons15.db from userdata and restart
(2012-09-22, 05:05)RizThon Wrote: Hi, I created a music video scraper at the beginner of the year with last.fm too
http://forum.xbmc.org/showthread.php?tid...#pid995041
Maybe you can compare the 2 and see if there are things to add in yours.
(2013-01-21, 19:01)garretn Wrote: I said addon's xml, not addon.xml.
You need to use the API key, you don't need to use the secret key at all. Make sure you replace it in both places it occurs, not just the first one.
