2012-07-14, 08:31
I wanted to know if there was a way to remote control xbmc from another xbmc install. For example I use xbmc on one computer but when I select things they play on a different xbmc install on another computer.
I know there is a web end that does something similar however I much more like the navigation skins used in the actual xbmc application. As a result it would be better to literally use a second xbmc sharing the same library to control the other xbmc install remotely.
I assume it would be something like when you select an item it can play locally or have an option to play on another system on the network.
